Hey guys, i've done a bit of a search but couldnt find much.
Anyway, just brought a tacho, and now im stumped as to how to wire it up. My original tacho only worked sometimes, very rarly. I've gone behind the cluster, and touched on the wires to the tacho to see if i could get signal, however couldnt find any on anywire.
So basically i want to know how to wire this tacho up? Can i grab it straight off the ecu? (im an Rb20E)
How has everyone else done it? is there any specific colours that the tacho wire usually is behind the cluster. Im lead to believe that a GTST cluster could go in, so it should be the same in theory...? kinda.
Thanks.
Dayne
https://www.sau.com.au/forums/topic/78502-wiring-a-tacho-r33/
You might have problems depending on the tacho type.
Basically you can try hooking up pin 7 as the signal wire and if that works you are laughing.
If that fails you can try a pull up resistor, then a tacho booster. Get back to us if you need more info on the last two.
Actually, speaking of the tachos, what form is the ECU tacho output? Is it the same as a central distributor lead in other cars? The reason I m asking is I was trying to hook up a rev meter to my car recently and according to the manual I needed to use a wire that hangs out next to the O2 sensor connector (that was designed for that purpose). I did that but I was getting the signal that was about 6 times less than the actual rev figure. I guessed it was only a signal from one spark plug, not all of them.
Funny thing about doing that is that my tacho was going crazy while I had the meter hooked up. It was showing the right idle but going crazy while revving - it was dropping to zero. It actually looked as though it was working in "reverse"
So now I m wondering if I can hook up the device to the ECU... Not trying to confuse the OP
Yeah i dont really know what that means, if you could fill me in a bit more it'd be great, im going to go try 'pin 7' now and i'll let yous know.
Dayne
Pin 7 is the signal wire that the OEM tacho uses (also need +12V and GND).
Some tacho's will work fine if their signal input is connected straight to Pin 7. Others don't work straight away and need a bit of fiddling, it just depends on the tacho. It seems less likely that the tacho will work if it was designed for a coil type ignition (eg some US tachos and EFI conversions into older cars) rather than an EFI application (eg Jap tachos).
Well thats what my tacho says, "Connect to coil ra ra ra" so i think i might need a tacho booster? is that correct? where can i get these from?? or what type of fiddling do you mean?
Also... how do i find wire 7 on the ecu? you guys said it was a green one, but the only green one i can seem to find is way up the list.
Tacho output is a 0-5V square wave.
But...
All pin 7 does is switch between open and ground. So to get a signal you need to connect a voltage source to pin 7. AFAIK this is done internally in the tacho (+5V). If you don't connect pin 7 to a voltage source then the ecu is just switching pin 7 between open (0V) and ground (0V) and therefore you don't get any signal. The upshot is that if you have an OEM tacho, and it works, then the tacho connection should work.
But this is just background info and doesn't really answer your question.
From what I remember the tacho output is actually a cylindrical connector with a single pin, are you sure you are measuring from the right place and you're not measuring from the timing light pickup loop?
Try connecting it straight to pin 7 first, if its a new tacho it might be designed for universal applications.
If it doesn't work you will still need to work out which wire is pin 7 anyway, plus you will need a +12V and GND sources, so you aren't really wasting any time if it doesn't work.
Righto, so that's why you need a pull up resistor. Yeah, I was connecting to the single pin cylindrical connector lower down the left strut tower, not the pickup loop.
Because there are 6 individual coils in a Skyline (ie one per cylinder), which makes for some fun wiring it up and designing circuits so that all the signals don't interfere with each other. God knows the sort of trouble you could get into. It's not like a old single coil car where you just have to piggyback onto a single wire to get the tacho signal.
IMO its much better to mess with non critical instrumentation wiring rather than start compromising the integrity of the wiring thats essential for reliable operation of the engine (ie splicing into coil wiring etc).
If the tacho doesn't work straight out of the box, then a pull up resistor might work and that is going to cost about $1. If you have tried this and it doesn't work, a tacho booster will only take 5 min to install, but it'll cost $50-100.
Whatever option ends up working, you are still going to need to locate the tacho signal wire, +12V and GND, so you might as well start with the cheapest option first...
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
