Hey guys,
***YOU CAN BUY ALL THESE PARTS IN ONE BIG CHEAP LOT***
Auto GTS Dash in great condition $offers
no longer showing any kays...
(could be used on a turbo car if you have your own boost gauge) (offers around $70)
A/C "radiator" (I think its called a condensor) (the thing that sits at the front) $150
A/C compressor, lines and all that stuff $150 (no gas of course)
If you want to full A/C system let me know, we will work something out.
Heater box (from behind the dash $50
Ashtry (with woodgrain for some reason) $15
Coil packs x 6. Checked them over and they look ok, no cracks or anything.. $140 the lot. Suit RB20DE, RB20DET, RB26DETT and S1 R33 GTS-T and RB25de of course.
Full R33 2 door dash with vents $130 (no cracks, looks fine)
Glovebox $20
Surround for cluster $15
Kick panels (both sides) no scuffs $20
Steering arms from both sides (woth stock suspension in good nik - no leaks) they are 4 stud though)
straight as (car wasn't damaged at front) Could be used to fix some damage if you got them re drilled for 5 studs with good rotors both sides $240 for both..
Steering Rack $100
ABS module $200
All plastics from around the front of a 33 (wheel arches and splash gaurd) $20
Brake lines (all of the metal ones) $20
Also have a VL N/A head, if anyone wants it $50, worked fine till it was pulled off (no noise or anything) car had 260000 kms.
I've got TONS of other bits, check back as I will update this. ask and I'll look, but its all the mechanical bits from the cut.
If anything here is stupidly overpriced tell me - we may be able to cut a deal... all prices are neg as I need to move this stuff out.
You could own ALL these parts for $320 plus pickup / postage. Make yourself some money and get the bits you need. I'm out of space and could use all this gone :(
Ask if you want something, I might have it. every single bit of the car has been taken out, cleaned and is ready for you!!!
Cheers!!!
Anthony
https://www.sau.com.au/forums/topic/78503-rb25-de-front-cut-leftovers-r33-bits/
does the R33 DE wiring loom have the knock sensor provisions in it? i need a loom for my 25/30 using the same head you have just bought but will be running a powerFC and obviously would like the knock sensor provisions to be in there, otherwise i guess i could wire them in manually.....
Hey guys,
skyline
I can seperate the airbox if I can get a buyer for the AFM..
StockyMcStock
I'm sure they are in there.
d00dz
I have the piece also for the same price :P You mean under the steering wheel, covering the adjustment underneath right?
Bump for the day.
Lotsa stuff to go.
If anyone is interested in a lot of parts, pm me so I can give you a better price :P
Cheers!
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
