Hey guys,
***YOU CAN BUY ALL THESE PARTS IN ONE BIG CHEAP LOT***
Auto GTS Dash in great condition $offers
no longer showing any kays...
(could be used on a turbo car if you have your own boost gauge) (offers around $70)
A/C "radiator" (I think its called a condensor) (the thing that sits at the front) $150
A/C compressor, lines and all that stuff $150 (no gas of course)
If you want to full A/C system let me know, we will work something out.
Heater box (from behind the dash $50
Ashtry (with woodgrain for some reason) $15
Coil packs x 6. Checked them over and they look ok, no cracks or anything.. $140 the lot. Suit RB20DE, RB20DET, RB26DETT and S1 R33 GTS-T and RB25de of course.
Full R33 2 door dash with vents $130 (no cracks, looks fine)
Glovebox $20
Surround for cluster $15
Kick panels (both sides) no scuffs $20
Steering arms from both sides (woth stock suspension in good nik - no leaks) they are 4 stud though)
straight as (car wasn't damaged at front) Could be used to fix some damage if you got them re drilled for 5 studs with good rotors both sides $240 for both..
Steering Rack $100
ABS module $200
All plastics from around the front of a 33 (wheel arches and splash gaurd) $20
Brake lines (all of the metal ones) $20
Also have a VL N/A head, if anyone wants it $50, worked fine till it was pulled off (no noise or anything) car had 260000 kms.
I've got TONS of other bits, check back as I will update this. ask and I'll look, but its all the mechanical bits from the cut.
If anything here is stupidly overpriced tell me - we may be able to cut a deal... all prices are neg as I need to move this stuff out.
You could own ALL these parts for $320 plus pickup / postage. Make yourself some money and get the bits you need. I'm out of space and could use all this gone :(
Ask if you want something, I might have it. every single bit of the car has been taken out, cleaned and is ready for you!!!
Cheers!!!
Anthony
https://www.sau.com.au/forums/topic/78503-rb25-de-front-cut-leftovers-r33-bits/
does the R33 DE wiring loom have the knock sensor provisions in it? i need a loom for my 25/30 using the same head you have just bought but will be running a powerFC and obviously would like the knock sensor provisions to be in there, otherwise i guess i could wire them in manually.....
Hey guys,
skyline
I can seperate the airbox if I can get a buyer for the AFM..
StockyMcStock
I'm sure they are in there.
d00dz
I have the piece also for the same price :P You mean under the steering wheel, covering the adjustment underneath right?
Bump for the day.
Lotsa stuff to go.
If anyone is interested in a lot of parts, pm me so I can give you a better price :P
Cheers!
  oscar32 said:
Hey guys,
skyline
I'll take the AFM... if its identical to the turbo one...?
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
