RB25 DE front cut leftovers... R33 bits
Hey guys,
***YOU CAN BUY ALL THESE PARTS IN ONE BIG CHEAP LOT***
Auto GTS Dash in great condition $offers
no longer showing any kays...
(could be used on a turbo car if you have your own boost gauge) (offers around $70)
A/C "radiator" (I think its called a condensor) (the thing that sits at the front) $150
A/C compressor, lines and all that stuff $150 (no gas of course)
If you want to full A/C system let me know, we will work something out.
Heater box (from behind the dash $50
Ashtry (with woodgrain for some reason) $15
Coil packs x 6. Checked them over and they look ok, no cracks or anything.. $140 the lot. Suit RB20DE, RB20DET, RB26DETT and S1 R33 GTS-T and RB25de of course.
Full R33 2 door dash with vents $130 (no cracks, looks fine)
Glovebox $20
Surround for cluster $15
Kick panels (both sides) no scuffs $20
Steering arms from both sides (woth stock suspension in good nik - no leaks) they are 4 stud though)
straight as (car wasn't damaged at front) Could be used to fix some damage if you got them re drilled for 5 studs with good rotors both sides $240 for both..
Steering Rack $100
ABS module $200
All plastics from around the front of a 33 (wheel arches and splash gaurd) $20
Brake lines (all of the metal ones) $20
Also have a VL N/A head, if anyone wants it $50, worked fine till it was pulled off (no noise or anything) car had 260000 kms.
I've got TONS of other bits, check back as I will update this. ask and I'll look, but its all the mechanical bits from the cut.
If anything here is stupidly overpriced tell me - we may be able to cut a deal... all prices are neg as I need to move this stuff out.
You could own ALL these parts for $320 plus pickup / postage. Make yourself some money and get the bits you need. I'm out of space and could use all this gone :(
Ask if you want something, I might have it. every single bit of the car has been taken out, cleaned and is ready for you!!!
Cheers!!!
Anthony
Hey guys,
skyline
I can seperate the airbox if I can get a buyer for the AFM..
StockyMcStock
I'm sure they are in there.
d00dz
I have the piece also for the same price :P You mean under the steering wheel, covering the adjustment underneath right?
 Share
