I have noticed that there are not many of these 1.5 series R33's why is that is it because they were simply a car that was manufacatured for a very very brief time or is there something else that I have over looked as to why there is not many available
https://www.sau.com.au/forums/topic/78507-series-15/
What's the difference between series 1-1.5 or 1.5-2???
I'm not too sure about the 1.5 series, but in another thread they mentioned all the differences between series 1 & 2, but my car has a few features of both, so maybe mine is a 1.5, otherwise it's a s1. Is there a way to tell easily or not???
https://www.sau.com.au/forums/topic/78507-series-15/#findComment-1432936
Mine is a R33 GTS-T 1994 Model, I think it's a Series 1.5 as it has an Airbag, but no ABS yet, one of those Antenna erection buttons (which I'm sure didn't come in Series 1's) and only has half a body kit (Front Bumper only and colour coded Mud guards, but no side guards and only standard rear bumper)
I looked all over the car and engine bay, but couldn't find the Series No. of the car anywhere.
https://www.sau.com.au/forums/topic/78507-series-15/#findComment-1433110
On the build plate it says 1994 but yet on the rego papers it claims 1995 ? still unsure as to the reasoning why this is my only guess is that it was made in 1994 but yet it was the 1995 model ....
Mine does have the nicer front bar and fog lights (just have to work out how to turn the foggers on) and the drivers air bag, the antenna up and down button ect
but thanks for that it was just a curiosity thing... had done a quick search but just wanted to know if it was like a limited edition ?
https://www.sau.com.au/forums/topic/78507-series-15/#findComment-1434211
check the build date on the bottom of the seatbelt, where it connects to the floor.
Also, there was a chassis number list somewhere that detailed the chassis number and the build year.
Although mine was built in 95, it was a 96 delivered model, and a series 2.
https://www.sau.com.au/forums/topic/78507-series-15/#findComment-1434251
I have a series 1.5 - its the last of the series 1 models so it has the beginnings of the S2 features but the so called "best" of the S1. As other people it said it has airbag, HICAS, series 2 rear wing etc Mine has the M-Spec front bar... which is a bit better looking than the standard S1 front bar.... I still like S2 ones's better though!
Its the same with most cars... the last model they make is usually the better one of the series.
https://www.sau.com.au/forums/topic/78507-series-15/#findComment-1435628
Have a series 1 in the driveway and a series 2 next door, nearly identical cars too hahhaha
Sit in both seats, look at both seats... the series 1 seats are much nicer infact the series 2 owner is getting new seats as we speak no bull!
Guess its personal opinion as with everything else aswell
https://www.sau.com.au/forums/topic/78507-series-15/#findComment-1443365
90 percent of R33s I have seen recently are Series 1.5.
There are variations, but really ONLY 1995 models can claim to be series 1.5
Even 1993 series ones came with optional Airbag, AND PASSENGER AIRBAG (it was a very expensive option and not common in 1993 cars hence you dont see many).
Series 2 had a fair few differences, most relevent to me are the suspension and turbo. The seires 2 suspension is much stiffer than Series 1 (as standard) and the turbo uses a Nylon front wheel (like a R34 GTT).
https://www.sau.com.au/forums/topic/78507-series-15/#findComment-1443408
yeha starion turbo is right, only series 1.5 are '95 model nothing else, its because its the model thats in between the two models that had been made. I have a series 1 '94 model but it has abs brakes no passenger airbags tho, series 2 wing, however i dnt have that button for that antennae thingo that Don is talking about
https://www.sau.com.au/forums/topic/78507-series-15/#findComment-1451040
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
    • Not required but appreciated. Super Coppermix Twin even the non-competition model feels like the pedal is noticeably heavier than stock which was pretty well judged IMO. I'll be swapping in the Nismo operating cylinder soon to see how that feels.  Personally I haven't felt anything that justifies replacing the damping loop, at least compared to more modern stuff where the clutch delay valve is actually quite noticeable.
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
