Hey car is a 96 r33 s2, car has been fine until last night. I was driving along and was in third gear, i started to accelerate, the car got to about 3500rpm then cut-out for a second. It was like a big jerk. Then further up the road i tried again and the same thing happen.
Today i took it for a drive and it was fine, but tonight when i went to accelerate it happend again. Im starting to think it might have something to do with the colder weather at night?
I also thought it might be boost cut. It is currently set at 12psi. The only thing i have changed lately was the boost controller. I went from a no name bleed valve, to a turbotech ($22 one from the forums). I think it may be getting just under 13psi sometimes (when its colder).
Anyways just wondering if anyone could help out.
P.S sorry if this post is hard to read, but im not in a good writing mood right now
Thanks, Mike
https://www.sau.com.au/forums/topic/78546-r33-problems-fuel-cut/
Don't change your afm unless you change your ECU - it will stuff things up. The AFM isn't maxed out but the reading the ECU is getting is saying this is too much airflow (most likely), hence richening and retarding the timing which feels like a fuel cut.
Turn the boost down to 10psi. If it stil happens look to coil packs for issues.
check to make sure the boost controller does not have a blockage. This would cause the turbo to spike extremely quickly as the wastegate is not opening or not opening enough. Your boost cut should be somewhere around 20psi but the turbo will hit that twice as fast as your guage will read it so it might only say 13 or 14 psi but the turbo has already hit 20psi. It is unlikely to be your AFM as my stock rb20 afm is putting through 250 rwkw and only reaches maximum voltage when my injectors hit 100% duty cycle.
  • 7 months later...
sorry to dig up an old thread....
but im currently getting these exact symptims from my car
only running fm cooler, pod and 3" cat back and cars at 9.5psi
doesnt haven all the time.. but its like a big jerk when it does happen
would that be a boost cut... at 9.5psi? :rolleyes:
-Ruffels
  • 1 year later...
-Ruffels
Im also getting the exact same problem. It seems to be worse at night and is definatly worse on higher boost, the higher the boost, the worse it is generally.
Has anyone found out what is actually causing this yet?
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
