Genuine Nismo GTS-R Manifold
Its been modified to suit a Turbosmart 45mm Ext gate.
Fits RB20/25 (and i assume RB30) heads.
Manifold is in perfect working order.
Price: $1100 Neg
Go see what R31House want for thier manifolds ;)
All been professionaly modified for the gate. Manifold will not be availiable until LATE JULY, but i have lots of interest from a few people who have herd im changing. Will ship wherever at your cost
Two pics attached... they are OLD pics before modifications were made. And its dirty to boot.
2nd diagram shows roughly where mods have been done.
Also comes with the Genuine Heat Shield that goes over it all
https://www.sau.com.au/forums/topic/78563-genuine-gts-r-manifold/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
