if you put it on a scooter or lawn mower i would say it'll work fine providing you limit boost to no more than 1.5-2psi and keep the revs below 2000. if you bought it for your car you should have a responsible adult remove your credit card from your wallet and close your ebay account.
https://www.sau.com.au/forums/topic/78567-xs-power-turbos/#findComment-1433984
the issue that ive have heard (not saying it is or isnt) is that the wheel isnt properly balanced which is causing it to loose a wheel under load.
Maybe getting it fully rebuilt or atleast checked by a local specialist to see if they can find something with the turbo before you bolt it on...
https://www.sau.com.au/forums/topic/78567-xs-power-turbos/#findComment-1434444
i reckon it would be a good upgrade on our old excel or maybe my daihatsu 1.6l NA engine. give it to me and i will tell you how it goes. hell if it works i'll even let you do some burnouts in it.
https://www.sau.com.au/forums/topic/78567-xs-power-turbos/#findComment-1434511
Hhhahahahaaa :)
I think the guy just needed to make a mistake to learn that he should research products before buying them.
Dont take it to heart man just get rid of it buy a proper unit and move on..
ps: make sure your buying quality next time ;)
https://www.sau.com.au/forums/topic/78567-xs-power-turbos/#findComment-1434512
you cut the corner by buying a very nasty turbo, and you want to cut the corners again by getting someone to balance it cheaper?
If I were you, I would try and sell it to buy a garrett or HKS unit. But the time you balance it etc, It might only last a couple of months.
Cheers
Sumo
https://www.sau.com.au/forums/topic/78567-xs-power-turbos/#findComment-1435976
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
