PRICE DROP $100 o.n.o looking for quick sale.
Pickup from Sydney only
Call Andrew - 0412 675 321
Not sure what brand/style - came with the car when i bought it.
Looks very good and gives that racer look. Is painted white and VGC. Selling due to returning car to stock form.
Pics below are exactly what it is :
https://www.sau.com.au/forums/topic/78572-fs-aftermarket-rear-wing-suite-r33/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
