Hey guys,
i have for sale a near new Autometer Phantom series 52mm Air/Fuel Ratio guage.
Features white face, easy to install ( 3 wires, 1 ear, 1 12v, 1 tapped into oxy sensor)
Purchased this for around $140 6 months ago
had little use, has minor scratching on outer rim (not on face)
other then this immaculate.
looking for $70
buyer pays post or pickup from east bris ;)
feel free to contact me on 0414829966
cheers
r1
Autometer site: http://www.autometer.com/cat_gaugedetail.aspx?gid=2606
actual pic: autometer1.jpg
https://www.sau.com.au/forums/topic/78581-bne-52mm-airfuel-ratio-guage/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
