  • Replies 97
Was talkin' to a couple of Norvac fella's the other day and they were tellin' me that some servo's (Caltex) round Tassie have been earmarked for PULP 98, just happens to be one of the earmarked one's right across the road from me! May be here sooner than we think!
https://www.sau.com.au/forums/topic/78592-pulp-98/#findComment-1468841
I spose any 98ron is good but I'd prefer BP ultimate.
earmarked, that could take years. And with the cost of 95PULP imagine how much they'll charge for 98 when it gets here. Tassie sucks, petrol way more expensive, houses way more expensive even for shitholes..... ... ..end rant sorry.
It's depressing trying to buy a house down here.
https://www.sau.com.au/forums/topic/78592-pulp-98/#findComment-1470055
YEP i know where your coming from Jaff
TASSIE SUCKS :chairshot
https://www.sau.com.au/forums/topic/78592-pulp-98/#findComment-1470160
I wouldn't complain to much about the cost of petrol here!! You should try some of the coastal towns along the Vic/NSW coast! When I was up there in Feb PULP was nearly $1.20 ltr then, was payin' nearly $1.30 for PULP 98!
As for realestate, well let's no start on that!
You don't know what your've got till you loose it!!
https://www.sau.com.au/forums/topic/78592-pulp-98/#findComment-1470910
Wouldn't it be cheaper to go to a servo on the mainland, and fill a 40 galon drum with 98ron, and bring it down with you for Targa? Or do you use that 100+ron stuff? There were afew cars running on left over F1 fuel accouple of years ago.
https://www.sau.com.au/forums/topic/78592-pulp-98/#findComment-1479909
yeah we looked at it but it is a logistical disaster, 500l of fuel carted all over tassie :) not to mention the rules required to ship fuel on the boat. All too hard so we just do the same as most people and buy it down there.
The serious guys are using the elf turbomax at ~$8 per litre.....for 500l....ouch...
https://www.sau.com.au/forums/topic/78592-pulp-98/#findComment-1480063
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
    • If it's been tuned idle rpm can be changed.
    • Very slightly as there are bars connecting both sides of the ramp. The only difficulty that I had was doing the gearbox, everything else so far has been ok
