  • Replies 97
I look forward to the ANDRA Sports compact day. should be good. Aslong as my car is running as it should.
BWAHAHAHHA
yeah i hear what your saying.
So much to do, so little time and not enough day light :rolleyes:
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1555293
when someone else is doing the work you can be a bit more pushy though... i want my car back in time  BIATCH!
yeah well i wouldn't want you giving me the stand over tactics TIMMAY!!!!
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1555345
  • 1 month later...
Hmm why does one servo tell you they will have it in a mater of months if not weeks and another tells you that tassie will never have it???
Is my car any closer? No, have i got a big shiny turbo yet? no, Have my hubs turned up yet? No.
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1635571
Yeah i know the feeling.
I have held of tuning my car in the even that it may of come down and it wasn't just BS that everyone was posting (should of know better <_< )
My car is no closer either Tim, but an up side.
I think i have found a Q to race :D
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1640088
you have too much money benny boi, share the love
WTF
Its a Q champ.
You buy a ready to race, roll off the tralior for $3k
THrow some tyres on, slap some happy gas in and your ready to race for $200 :lol:
Oh and i would love to see the look on Toff's face when he can't catch me :(
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1642813
  • 1 month later...
Launceston Tasmania
Legana Liberty have it, i only just found out... dunno how long its been there, the guy there said that he would expect all other liberties to follow suit
I am going there tonight just to check it out
please explain? where exactly is here
Edited by Edstrodamous
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1720928
hmm, do liberty buy their fuel from one of the major suppliers?? If so, which one.
Well i hope its on its way down south as well.
make life a hell of a lot easier thats for sure.
Otherwise its a pretty long trip up north to fill up everytime :)
Cheers B
https://www.sau.com.au/forums/topic/78592-pulp-98/page/4/#findComment-1721519
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
