  • Replies 97
I heared the same... Have had no confirmation that it has made it down to the good end of hobart yet  :)
How much is it up there? $1.50? Will it make an untuned turbo import run noticeably better?
Use 98RON when you get it tuned and tell your mechanic you're using it.
Dave Griffiths told me he'd play around with the timing with 98RON but would leave it as stock for 95RON.
With no tune you wouldn't notice the difference.
https://www.sau.com.au/forums/topic/78592-pulp-98/page/5/#findComment-1722926
Consumption will improve with a swap to 98, but the performance will remain the same until tuned specificly for 98.... as JaFF said.
98 is a better base product though as its designed to be 98 when blended. 95 can be anywhere within 2 points -/+ I understand.
https://www.sau.com.au/forums/topic/78592-pulp-98/page/5/#findComment-1723238
Ok here is what i know, Premiumax is what it is called, the guy behind the counter said that it has more ron than premium unleaded but they could not guarantee it was 98 what ever the fook that means. i have the little brochure somewhere i will find it, i am trying it in my car, Liberty Mowbray also have it. price is $1.27-29, of course i have not been for a tune yet but will soon then we will see how it goes. Have to run another tank through it anway.
Just ring up Legana for questions. I will report back with a scanned copy of the brochure when i can.
I think premiumax needs testing for an accurate figure,
cheers ed
any updates at all fella's???
Edited by Edstrodamous
https://www.sau.com.au/forums/topic/78592-pulp-98/page/5/#findComment-1759959
BP Ultimate should be at the pump by jan/feb 06. burnie where most fuel in the north gets delivered from is seting up now.
How certain are we of this? I'll cream my shorts if we get it that soon!!
https://www.sau.com.au/forums/topic/78592-pulp-98/page/5/#findComment-1804494
  • 1 month later...
well start creaming then
p.s dont tell anyone about this i got told today by my boss and he said not to tell anyone ok lol
so is it this true or still BS that we are getting better fuel here for a change???
https://www.sau.com.au/forums/topic/78592-pulp-98/page/5/#findComment-1911218
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
