Hi all,
I'm interested in both 180sx and skyline R33
I'm currently leaning towards skyline.
Don't get me wrong, both cars are good.
I would like to assume that the skyline is more expensive to maintain.
But how much more?
which is better in term of value for money, performance to cost/maintainence ...
comfort wise definitely skyline.
found a 1995 skyline with hks coils, pod filter, 134000km selling for $16k
. is the car expensive?
(the car is basically stock)
Thankz
  • Replies 68
- I think for a pretty much stock car you should be able to get a better price than that.
- Have you looked at the S2 R33, imo they look better + are newer..
- you have options whether you want one already sold in Aus - or a fresh import..
- When getting a skyline it will be a newer car generally than a 180sx however will be slightly more expensive..
- pretty much comes down to personal preference..
- i prefer safety over old cars - hence getting skyline with ABS and Dual Airbags.. but that's a personal reason..
- You also want to look at resale price.. if you put an extra 30,000kms on it than your resale will drop..
- are you wanting private or dealer..
If you want down right balls... go a 180sx.
They look hot and go hard, simply because they are lighter than all the skyline range!
If you want interior comfort then a Skyline is worlds apart.
Skylines are a mix of looks, comfort and performance where as the 180sx can look good but is just a very good performance car. Abit older + a boring interior makes the Skyline a better choice in my opinion.
yeh, depends on what you can handle. my mate has a modded 180, 244rwkw. my line has 220rwkw.
the 180 is damn quick, breaks traction on boost, handles and goes like a rocket....but its loud and rattly, bounces over bumps at speed, really really light, steering feels a bit iffy due to the strut set up. but power is like an on/off switch, hits really hard. good engine to work on, lots of room in engine bay. very strong reliable motor.
the 33, is more refined, a bit slower, but not by much, specially with stock turbs, smoother engine, smoother power delivery, its alot easier to cruise in. the interior is much nicer, more bearable. steering and handling is alot better due to the more advanced suspension and the extra weight stops it from bouncing all over the road.
all depends on how much money you have and what you prefer the look of, you can always put an RB in the 180..
cheers
Linton
R32GTR! they cost like 22-28k
i can't afford that, i wish i can though.
how much do u spent on ur skyline r33 gtst per month. fuel etc?
trivial question , how much is the transfer fee for vehicles like that (180/skyline)?
Just got a bank loan for 15k and i don't wanna go overboard with my finance ..
(who doesn't? :))
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
