  • Replies 68
also 16k for a pretty much stock car isnt that good, i payed 14,500 for mine. ( '94 R33 GTS-T S1 )
Personally I would pay more for a stock car - pretty rare to find a skyline that hasn't been modded and had the sh!t caned out of it. Besides doing your own mods is more fun.
I was in the same boat, I was tossed up between a skyline and a 180, for my price range I could only pretty much get a stock 32 or a 180 with minor mods.
then a widebody sil80 with heaps of mods popped up on auction for 11-12k and I fell in love, never looked back.
Am i right when i say that s1 comes with airbag n abs as well?
No unfortunately your aren't, even in the S2 ABS is a an optional part that alot of cars don't have.
The S1 - some have ABS and Airbags, 95% won't have ABS at all, and not a huge number have Airbags..
Also you will probably pay more for a car that has these depending..
mines lightly modded ( 3" straight though exhaust, pod and now body kit ), plus its only done 60,000 kms.... not bad for a '94 model.... its pretty much new still ( and yes they are genuine kms, coz before i bought the car i got it checked out by the racv dudes... them dudes dont like imports either, so they were particular about everything.,... including a spot of gum on the back seat ).
Well r33s are more classy...
If you wana pull girls the Skyline is definately the go lol
so true, even the way my car is now ( damaged, about 2 get fixed ).... chicks still love it lol. ahhhh skylines, is there anything they cant do :cooldance
i once met a girl who after a few beverages told me her fantasy was to be shagged on the bonnet of a v8powered car whilst the engine was being revved
man that was one nasty girl
So did you get her phone number?
I'd have dropped her onto the bonnet of a worked R32 GT-R and, as I was doing her doggy style with my mate blipping the throttle and giving her a BOV-job while I'm rogering her, just kept yelling "GT-R can nevar lose!".
Personally, I'd get a 180SX. Lighter car so it should go a bit quicker in the twisty stuff. I also really like the way it looks. But that's just me.
If you want something a bit more comfortable while still being quickish, get the Skyline.
On this topic.
If my dash has an ABS light thats visible when all the dash lights are on does that mean I have ABS?
Are there any other ways of finding out other than some hard braking :P?
Oh, 1993 R33 GTST
a 180 is more of a sexier styled sports car, where the skyline is a grand tourer, slightly bigger, much nicer interior, more smoother/less twitchy (mates silvia is twitchy in all areas of design), there both good cars, you'll probly get better fuel consumption on the 180. It depends on what your needs are. A good skyline is a good 'all-rounder' while the 180 is a sports car and tries to be nothing else.
I have a nicely modded R33 (240rwkw) but I still sometimes think I should have gotten the 180sx as I know they're a much lighter and sportier car, and I drive for the thrill and speed, not the comfort or to pick up women.
But yeh, the R33 is a very nice car and feels solid and smooth on the road even at speeds in excess of 200km/h (track :)) so definately an A+ cruiser, but a B+ racer.
Just depends on what you want out of a car :P
the 180 is damn quick, breaks traction on boost, handles and goes like a rocket....but its loud and rattly, bounces over bumps at speed, really really light, steering feels a bit iffy due to the strut set up. but power is like an on/off switch, hits really hard. good engine to work on, lots of room in engine bay. very strong reliable motor.
the 33, is more refined, a bit slower, but not by much, specially with stock turbs, smoother engine, smoother power delivery, its alot easier to cruise in. the interior is much nicer, more bearable. steering and handling is alot better due to the more advanced suspension and the extra weight stops it from bouncing all over the road.
cheers
Linton
:werd: i own both and couldnt have sumed it up any better. remember though for bout 16k you can also get the 180sx type x model which has a much more update interior seat wise but the dash/console is still bland.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
