  • Replies 68
well they wud both be around mid 14s really if in pretty damn good nick...
Generally its just the 180s lighter weight that makes em quicker, s15 SR20s make the same power as R34 RB25s!!! And more torque aswell, dont quiet get how but seen proof in SPEED mags dyno. S13 sr20s arent as powerful stock or done up (dont ave vvti and smaller turbos etc) but still very good bang for buck and heaps of potential.
300rwhp in a 180sx is alot faster than 300rwhp in an R33
These are the times i consistently see:
Dead Stock sr20det s13 (silvia/180sx) - 14.5 secs
Dead Stock r33 gts-t - 15.3 secs
I remember when I had my s13 before the exhaust mod, I lined up against a friend in his modified r33 gts-t with fmic, exhaust and boost.. he was a bit ahead but could not pull away from me.
We had another race when I got the 3" straight through system on and I left him behind by a couple of car lengths.
Consequently all the gtst's I lined up against after that that did not have serious amounts of work done to them got smoked..
When your sitting behind the wheel they just feel bigger and heavier.
See i disagree, i think the R33s weight isnt much of a problem, being behind the wheel of one quiet abit before i was VERY suprised at how easy you can chuck them aswell. They dont feel like heavy cars at all, maybe due to the rb25 engine im not sure but they are very very very well built cars!! Saying that of course the s13-s15 range is going to feel lighter they are aswell as being smaller, go in an Integra and you'll think the same about an s13 lol
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
