  • Replies 68
well they wud both be around mid 14s really if in pretty damn good nick...
Generally its just the 180s lighter weight that makes em quicker, s15 SR20s make the same power as R34 RB25s!!! And more torque aswell, dont quiet get how but seen proof in SPEED mags dyno. S13 sr20s arent as powerful stock or done up (dont ave vvti and smaller turbos etc) but still very good bang for buck and heaps of potential.
300rwhp in a 180sx is alot faster than 300rwhp in an R33
These are the times i consistently see:
Dead Stock sr20det s13 (silvia/180sx) - 14.5 secs
Dead Stock r33 gts-t - 15.3 secs
I remember when I had my s13 before the exhaust mod, I lined up against a friend in his modified r33 gts-t with fmic, exhaust and boost.. he was a bit ahead but could not pull away from me.
We had another race when I got the 3" straight through system on and I left him behind by a couple of car lengths.
Consequently all the gtst's I lined up against after that that did not have serious amounts of work done to them got smoked..
When your sitting behind the wheel they just feel bigger and heavier.
See i disagree, i think the R33s weight isnt much of a problem, being behind the wheel of one quiet abit before i was VERY suprised at how easy you can chuck them aswell. They dont feel like heavy cars at all, maybe due to the rb25 engine im not sure but they are very very very well built cars!! Saying that of course the s13-s15 range is going to feel lighter they are aswell as being smaller, go in an Integra and you'll think the same about an s13 lol
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
