well driving on the highway down to sydney and in the distance i see what appears to be a big YELLOW dildo.....
quickly speed up screaming " OHHHH minh OHHHHH minh"
suddenly the rear lights start looking like an r34's lights... then i start to see the white wheels..... at this point im thinking.....
could it be ??? could it really be franks R34 ???
speed up some more get in front of it..... then i get the high beams of approval and whatdya know its franks....
our attempts to communicate failed as it was raining and i could open my window to scream at him....
he produced his CB but all i could show back was my mobile phone (NOTE: always carry CB in car)
anyways thats my boxing day story.......
https://www.sau.com.au/forums/topic/7860-franks-is-sexy/
  • Replies 55
WOW!!!
Yeap always carry a CB
https://www.sau.com.au/forums/topic/7860-franks-is-sexy/#findComment-114694
UR2EZ, Frank (is that your name?) too funny .... as you went past i knew straight away it was you. the DR GTR humping machine :mad: i would've taken a pic but my camera was in my uncles car!
we must've cruised for atleast 30 mins down the F1, was good that i had some company! your car seems as though its got abit stick too! would've loved to have stretched the car out, but there was too much traffic and too many cops! how was that radar trap we missed in the 90 zone!!!
by the way guys, its Channel 34 ;) ....the CB lives in the glovebox, do not remove it! :D
were you coming down from Newcastle or something? how freaky i see Ed at the entrance aswell today! was coming over the big bridge from the North in the Entrance and i see a black Neon, comes closer and the plates are like a blinding realisation that it was THE ed....cool :D
https://www.sau.com.au/forums/topic/7860-franks-is-sexy/#findComment-114787
na i was coming from toukley (10-15 mins from entrance... hahahaha)
hahahahahah glad to see i made a name for myself....
ya i know about 200 meters before it i was on 110 pissing off that laser with a cannon tip.... if the car in front of me wasnt there going to the speed limit i would have gotten busted for sure....
ya if i didnt have someone to play along the freeway i would have fallen asleep.... ya the little girl has some GOOOO in her.... though you have to many cubes for me to compete top end baby...... and the cops.... PWAOHHHH..... did u see the cops under the bridge.... 2 of them on bikes...... putting on their nice fluro yellow raincoats..... anyways whats ya mob.. next time your up the entrance way gimme a buzz.... can meet up at the entrance and do some fishing ;) (not in the bedroom) or have something to eat... (and before you ask im not on the menu, specials are servered after 10 o' clock thankyou..)
and yes FRANK's the name
https://www.sau.com.au/forums/topic/7860-franks-is-sexy/#findComment-114844
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
