  • Replies 55
Originally posted by franks
tht 78 dolla one is okay, only gripe is that it doesn't hold the last channel everytime you switch it on...???
that is correct.
the $99 is probably what most of us have and being a uniden, there is accesories such as external speaker etc for it.
speaking of 33's - i saw a couple of nice ones yesterday in blacktown.....
white S2 with a kit some big wheels, plates were RNAMUK or something like that... and a nice maroon one with the plates NOS200 or somerthing, had a GT-R wing and i forget the kit
How come you sit up in the repeater channels ??
(31 to 38) - It's technically illegal, but more so, it pisses others off...
Repeater Output - Channels 1 to 8 inclusive,
Repeater Input - Channels 31 to 38 inclusive.
How do you work through a repeater?.
All modern UHF CB transceivers have the function of being able to select duplex on channels 1 to 8. What this does is configure the transceiver to transmit on a channel 30 channels higher in frequency (called the repeater offset), every time you press your microphone button to transmit, but still receive on the channel you have selected. Therein lies the clue to the way repeaters operate - receiving your transmissions on the higher frequency, say in the case of a channel 4 repeater, channel 34, and retransmitting your transmission on the lower frequency, channel 4, so that all transceivers tuned to channel 4 in the footprint of the repeater will hear your transmission, as relayed from the repeater.
The downside of repeaters is that they tend to attract the "moronic" element due to their large coverage area. As the Authorities seem little interested to contribute to any policing of the band, it is largely up to the UHF operators to conduct themselves in a proper manner on the air and in doing so set a good example to others. There will always be that rebel element who, when behind the anonymity of a microphone cause trouble. Just remember that to respond to these individuals is to reinforce their very existence. Getting responses back can only increase their satisfaction of what they do. So the moral of the story is DO NOT RESPOND. It is the only weapon the responsible operator has of maintaining some degree of control over the quality of the UHF CB band.
easy...
you talk on chanels 1-8
and you listen on channels 30-38
eg. you talk on channel 4
you listen on channel 34
Question to South (it's PL97 here :mad: ):
Can you still use this function if you are outside of the range of a repeater? Do you need a repeater station setup inorder to use the duplex function?
so does that mean you can't "listen" on channel's 1-8 ? ;)
how are you suppose to have a decent converstion?
you'd say something on channel 4 for instance, and then switch to channel 34 for the response, then switch back?! :D
I think the unit transmitt on 4 and receives on 34 automatically franks. :mad:
EDIT: shoulr be other way around...receive on ch4 and send via ch 34 :D
I still don get it ???
If you are on Ch4 do you have to switch to Ch34 to Listen ?? That sounds off.
Sounds like we need to change to Ch RB_25_DET (Channel 25) for the standard UHF channel now......
:mad:
ok I *think* this is how it works if your unit supports duplex :mad:
- you are on ch4 and have setup to use duplex mode.
- you press the button to talk and the unit sends your voice over as ch34 to the repeater (4 + 30 = 34 wow)
- repeater receives your signal and broadcast it back out as ch4
- everyone on ch4 hears your voice
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
