  • Replies 55
Originally posted by franks
tht 78 dolla one is okay, only gripe is that it doesn't hold the last channel everytime you switch it on...???
that is correct.
the $99 is probably what most of us have and being a uniden, there is accesories such as external speaker etc for it.
speaking of 33's - i saw a couple of nice ones yesterday in blacktown.....
white S2 with a kit some big wheels, plates were RNAMUK or something like that... and a nice maroon one with the plates NOS200 or somerthing, had a GT-R wing and i forget the kit
How come you sit up in the repeater channels ??
(31 to 38) - It's technically illegal, but more so, it pisses others off...
Repeater Output - Channels 1 to 8 inclusive,
Repeater Input - Channels 31 to 38 inclusive.
How do you work through a repeater?.
All modern UHF CB transceivers have the function of being able to select duplex on channels 1 to 8. What this does is configure the transceiver to transmit on a channel 30 channels higher in frequency (called the repeater offset), every time you press your microphone button to transmit, but still receive on the channel you have selected. Therein lies the clue to the way repeaters operate - receiving your transmissions on the higher frequency, say in the case of a channel 4 repeater, channel 34, and retransmitting your transmission on the lower frequency, channel 4, so that all transceivers tuned to channel 4 in the footprint of the repeater will hear your transmission, as relayed from the repeater.
The downside of repeaters is that they tend to attract the "moronic" element due to their large coverage area. As the Authorities seem little interested to contribute to any policing of the band, it is largely up to the UHF operators to conduct themselves in a proper manner on the air and in doing so set a good example to others. There will always be that rebel element who, when behind the anonymity of a microphone cause trouble. Just remember that to respond to these individuals is to reinforce their very existence. Getting responses back can only increase their satisfaction of what they do. So the moral of the story is DO NOT RESPOND. It is the only weapon the responsible operator has of maintaining some degree of control over the quality of the UHF CB band.
easy...
you talk on chanels 1-8
and you listen on channels 30-38
eg. you talk on channel 4
you listen on channel 34
Question to South (it's PL97 here :mad: ):
Can you still use this function if you are outside of the range of a repeater? Do you need a repeater station setup inorder to use the duplex function?
so does that mean you can't "listen" on channel's 1-8 ? ;)
how are you suppose to have a decent converstion?
you'd say something on channel 4 for instance, and then switch to channel 34 for the response, then switch back?! :D
I think the unit transmitt on 4 and receives on 34 automatically franks. :mad:
EDIT: shoulr be other way around...receive on ch4 and send via ch 34 :D
I still don get it ???
If you are on Ch4 do you have to switch to Ch34 to Listen ?? That sounds off.
Sounds like we need to change to Ch RB_25_DET (Channel 25) for the standard UHF channel now......
:mad:
ok I *think* this is how it works if your unit supports duplex :mad:
- you are on ch4 and have setup to use duplex mode.
- you press the button to talk and the unit sends your voice over as ch34 to the repeater (4 + 30 = 34 wow)
- repeater receives your signal and broadcast it back out as ch4
- everyone on ch4 hears your voice
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
