you mean the 3 centre guages? not a really big deal as you can't use the torque guage. nengun have an upgraded one for $360 brand new delivered to melbourne
oost 0.8 + 1.4kg/cm2
Temperture 60 - 140 C
Front Torque 0 - 50kgm
in white or black. however you already have stock boost guage and temperature and the torque guage wont work so its kinda pointless. would much prefer the stock guages instead of those ones in the middle
https://www.sau.com.au/forums/topic/78624-r33-gtr-dash/#findComment-1435156
hi paul,
no i mean the whole thing. The cluster with higher spec speedo and tacho, as well as the three guages for boost, water temp and torque guage (which i know is useless on gts-t)
https://www.sau.com.au/forums/topic/78624-r33-gtr-dash/#findComment-1435223
Sorry to go offtopic, but the centre console guages for R33 GTR... would they mount up in an R32?
Upgrade or add a Nismo White Sub Console Meter to Your Nissan Skyline BNR32
Boost 0.8 + 1.2kg/cm2
Temperture 70 - 150 C
Voltage 6 - 18 V
for $530 delivered. however all the guages are DIN size meaning they are universal so they should any car and any DIN slot. it would just be different guages and screw holes. the bnr33 has boost water and torque whereas bnr32 has boost temp volts
https://www.sau.com.au/forums/topic/78624-r33-gtr-dash/#findComment-1435249
I think the price of guages is a lot of shit. Most people prolly say a wank, unless your car is on the limit.,
im disappointed that their is no oil temp anywhere. also hear the std boost isnt accurate enough?
cant recall seeing battery level on dash too, altho if it gets to that point, alternator or battery are stuffed. just keepa multimeter handy.
https://www.sau.com.au/forums/topic/78624-r33-gtr-dash/#findComment-1435581
yeah actually the r33 doesnt have a battery meter (well gtst) it has a warning light tho
no oil temp sucks hey, probably cos theres no stock sender unit for it
i dont see how the stock boost guage couldnt be accurate unless plumbed incorrectly?
my evc and boost guage show pretty much spot on the same pressure
https://www.sau.com.au/forums/topic/78624-r33-gtr-dash/#findComment-1435600
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
