I've got an R33 GTS-T, I've potentially got an oil pressure problem... the gauge sits low at idle (at about 1), but when up in it sits at about 4. Does anyone know if:
1. nissan oil pressure gauges are dodgy
2. nissan oil pressure sensors are dodgy
3. GTS-Ts have dodgy oil pumps.
From the way it drives it seems to be fine.
If it is the oil pump what on average is the cost of part/repair?
Thanks.
https://www.sau.com.au/forums/topic/7863-low-oil-pressure/
Ronin 09,
As far as I know, Nissan don't have dodgey senders/gauges etc. However it is common for the oil pressure sender to fail. This is usually due to poor maintenance rather than a defect in manafacturing.
With regards to your pressure it does seem low. Idle should be around 2 at 6k rpm it should be around 6. The first thing I would do is try an aftermarket gauge. Then replace oil sender, then go from there.
Also check that you are running a high quality synthetic oil Eg Mobil 1 5w-50w. If you search the forums you will find many other suggestions for oil.
Regards,
Tim
https://www.sau.com.au/forums/topic/7863-low-oil-pressure/#findComment-115007
The Skyline senders are well known to give low readings.
Like hitnrun said, more of a maintance thing that a manufacturing thing.
Mine did this once. I gave it a drink of good qual oil and a change of filter and haven't looked back.
If you start to hear a rattle, turn it off REAL FAST !! :uh-huh: :uh-huh: :uh-huh:
J
https://www.sau.com.au/forums/topic/7863-low-oil-pressure/#findComment-115033
Thanks guys, haven't heard any spooky noises or anything, so i assume it is the sender. Sometimes tries to stall at idle, but i think the idle is set too low (450-500 RPM)...
I've just got my car fresh from importing, and have not had a chance to change all the fluids yet. Problem is i'm pretty useless mechanically, and all the shops are closed till at least the 6th. I'll report back when i get the fluids changed / a service and get them to look at the pressure sender.
Any recommendations of shops to get my car serviced in Melbourne? Using Evolution R, but they seem pretty $$!
-marcus
https://www.sau.com.au/forums/topic/7863-low-oil-pressure/#findComment-115051
  • 4 months later...
Dremen, i've had a couple of oil changes, and it has steadily gotten better. Apparently the sensors are quite sensitive to crap oil. I've used Mobil 1 5-40W, and just last change went to Motul 3000 15-50W. Just use a quality oil, you should be right
https://www.sau.com.au/forums/topic/7863-low-oil-pressure/#findComment-308930
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
