I've got an R33 GTS-T, I've potentially got an oil pressure problem... the gauge sits low at idle (at about 1), but when up in it sits at about 4. Does anyone know if:
1. nissan oil pressure gauges are dodgy
2. nissan oil pressure sensors are dodgy
3. GTS-Ts have dodgy oil pumps.
From the way it drives it seems to be fine.
If it is the oil pump what on average is the cost of part/repair?
Thanks.
https://www.sau.com.au/forums/topic/7863-low-oil-pressure/
Ronin 09,
As far as I know, Nissan don't have dodgey senders/gauges etc. However it is common for the oil pressure sender to fail. This is usually due to poor maintenance rather than a defect in manafacturing.
With regards to your pressure it does seem low. Idle should be around 2 at 6k rpm it should be around 6. The first thing I would do is try an aftermarket gauge. Then replace oil sender, then go from there.
Also check that you are running a high quality synthetic oil Eg Mobil 1 5w-50w. If you search the forums you will find many other suggestions for oil.
Regards,
Tim
https://www.sau.com.au/forums/topic/7863-low-oil-pressure/#findComment-115007
The Skyline senders are well known to give low readings.
Like hitnrun said, more of a maintance thing that a manufacturing thing.
Mine did this once. I gave it a drink of good qual oil and a change of filter and haven't looked back.
If you start to hear a rattle, turn it off REAL FAST !! :uh-huh: :uh-huh: :uh-huh:
J
https://www.sau.com.au/forums/topic/7863-low-oil-pressure/#findComment-115033
Thanks guys, haven't heard any spooky noises or anything, so i assume it is the sender. Sometimes tries to stall at idle, but i think the idle is set too low (450-500 RPM)...
I've just got my car fresh from importing, and have not had a chance to change all the fluids yet. Problem is i'm pretty useless mechanically, and all the shops are closed till at least the 6th. I'll report back when i get the fluids changed / a service and get them to look at the pressure sender.
Any recommendations of shops to get my car serviced in Melbourne? Using Evolution R, but they seem pretty $$!
-marcus
https://www.sau.com.au/forums/topic/7863-low-oil-pressure/#findComment-115051
  • 4 months later...
Dremen, i've had a couple of oil changes, and it has steadily gotten better. Apparently the sensors are quite sensitive to crap oil. I've used Mobil 1 5-40W, and just last change went to Motul 3000 15-50W. Just use a quality oil, you should be right
https://www.sau.com.au/forums/topic/7863-low-oil-pressure/#findComment-308930
