good stuff. a couple of questions. what does it weight now? also, it may just look that way, but are they different diameter rims front/rear?
also a tip. easiest (if you can call it that) way i have found for removing the tar is to use a heat gun and a scraper. much quicker than just trying to scrape it off.
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
