Clutch has lightened fly wheel and 75-80% left, rated @1000 hp.
Out of my GTR R32.
Doing major up grade, larger main shaft Pffizner box, hence different clutch.
Who ever buys will be happy.
$1000.00 ono SOLD-- Thanks chaps.
]PERTH WA
https://www.sau.com.au/forums/topic/78653-os-giken-triple-plate/
Out of my GTR R32.
$1000.00 ono
All OSG clutches for GTR are push type. They sell a conversion kit seperately to allow fitting to a pull type setup as fitted to late R32 and R33 GTRs.
Thanks Gav, i should of explained a little clearer.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
