ok, i will take some pics tonight. do we want a static pic, or perhaps one with some smoke??
i am already thinking about RB26 head to go onto the 30. hmm. it's such a sick car. it has blue velour interior. a bit of niki, dodgy dash. it has a kick arse little lip spoiler. has nearly 300 000kms on it but fatz tells me that means it is just run in and now ready to pull some big power. came with 8 wheels. 4 genuine sillo alloys, 2 steelies and 2 'toyota' wheels which had to be machined to fit...
got a GT wing ready to go on, and some carnard spoilers for the front end downforce i need. noice.
  • Replies 125
for sure 600 31s will be pretty sweet. apparently the dude from 31house has quite a few. that will be a start.
spewing that clutch is in the death wagon.
so jimbo, when you buying a 31?
31 is good in that i can fit a few spare wheels+tyres in the back and still manage a few slabs off beer in there too.
Pete, stop posting under Rich's account :spcow:
yeah 16 tyres but how many cans and how many chicks. god knows when a chick sees you driving down the street in a 31 with all that rubber in the back she will want to jump in for sure. then you will need a few beers to entertain her properly.
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
