Maxxis Tyres
Manwh0re
That is a full coincidence.
My name is MANWHOR3 - I live in sydney.
My friend's name is MANWHORE - he lives in Sydney too.
You're name is Manwh0re - you're in sydney. you joined a year before us. hmmm...
Haha I'm the original...
If you have a R34 as well.... well I'll be damned..
got the catalog from BOb Jane, and 255/40/17 are not aviable in the country for another 6 weeks
If you are in Sydney i can get you Toyo 255x40x17 ( proxes T1S ) for about $260 each .
Let me know if you are interested and i'll find out the price for you .
Check them out on the website http://www.toyo.com.au/
Go the Hankook Ventus Sport K104 235x40x17 at $175 a tyre. Theyre top quality, have been chosen as OEM supplier for many big car companies etc.
I dont believe for a second any of the crap quality talk about tyres from Asia. Most companies make their tyres is asia, simply because its cheaper. The days when china/taiwan/etc being synonomous with crap quality are long over. The vast majority of companies have strict quality control proceedures, most are ISO9001 certified.
Please give me one decent brand that makes a performance tyre in an Asian country that's not Japan or Korea?
OK i dont know any of the top of my head, but if anyone wants to check where their paticular set of tyres were made click on the link below and search for the manufacturers code which is on the tyre sidewall:
http://www.tireaccidents.com/tire_plant_codes.htm
I was wondering if any of you guys out there have tried some Maxxis tyres,   Victra Ma-Z1 235/45/17  to be more precise (Finished 3rd overall in wheels magazine test last month).  if so tell us about your experiences with them.
I am seriously thinking in buying some at 180 dollars a corner ;)
Cheers,
I have a set of 235/45/17 MA-Z1 on the front and they seem to be pretty good. Have done a few short track days with them and they held up really well. Great in the wet. I also have toyo t1s on the rear (255/40/17) and the tread pattern between the 2 is almost identical.
I used to have crappy Nankang ns1 on the car and they were supremely shite! Did one track day in them and understeered my way all over the place. The maxxis didnt have any troubles like they did, ran the same setup with both sets of tyres. Hope this helps.
Cheers
They are made in Taiwan, if anyone is interested in continuing with the quality control debate :P
Treadwear rate 280 traction AA, same as Dunlop Sport 9000, GoodyearEagle F1 GS-D3, Michelin Pilot Sport, and others more expensive tyres, so no extra soft compound here, as many were implying.
 Share
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
