Maxxis Tyres
Manwh0re
That is a full coincidence.
My name is MANWHOR3 - I live in sydney.
My friend's name is MANWHORE - he lives in Sydney too.
You're name is Manwh0re - you're in sydney. you joined a year before us. hmmm...
Haha I'm the original...
If you have a R34 as well.... well I'll be damned..
got the catalog from BOb Jane, and 255/40/17 are not aviable in the country for another 6 weeks
If you are in Sydney i can get you Toyo 255x40x17 ( proxes T1S ) for about $260 each .
Let me know if you are interested and i'll find out the price for you .
Check them out on the website http://www.toyo.com.au/
Go the Hankook Ventus Sport K104 235x40x17 at $175 a tyre. Theyre top quality, have been chosen as OEM supplier for many big car companies etc.
I dont believe for a second any of the crap quality talk about tyres from Asia. Most companies make their tyres is asia, simply because its cheaper. The days when china/taiwan/etc being synonomous with crap quality are long over. The vast majority of companies have strict quality control proceedures, most are ISO9001 certified.
Please give me one decent brand that makes a performance tyre in an Asian country that's not Japan or Korea?
OK i dont know any of the top of my head, but if anyone wants to check where their paticular set of tyres were made click on the link below and search for the manufacturers code which is on the tyre sidewall:
http://www.tireaccidents.com/tire_plant_codes.htm
I was wondering if any of you guys out there have tried some Maxxis tyres,   Victra Ma-Z1 235/45/17  to be more precise (Finished 3rd overall in wheels magazine test last month).  if so tell us about your experiences with them.
I am seriously thinking in buying some at 180 dollars a corner ;)
Cheers,
I have a set of 235/45/17 MA-Z1 on the front and they seem to be pretty good. Have done a few short track days with them and they held up really well. Great in the wet. I also have toyo t1s on the rear (255/40/17) and the tread pattern between the 2 is almost identical.
I used to have crappy Nankang ns1 on the car and they were supremely shite! Did one track day in them and understeered my way all over the place. The maxxis didnt have any troubles like they did, ran the same setup with both sets of tyres. Hope this helps.
Cheers
They are made in Taiwan, if anyone is interested in continuing with the quality control debate :P
Treadwear rate 280 traction AA, same as Dunlop Sport 9000, GoodyearEagle F1 GS-D3, Michelin Pilot Sport, and others more expensive tyres, so no extra soft compound here, as many were implying.
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
