1994 r33 gtst
big hit up the ass car written off
whole car being dismatled at home
prices will be added here as peole request them
alraedy sold :
castor rods
injectors
turbo
afm
exhaust
fuel prssure reg
coilpacks
wheels
suspension
steering wheel
front seats
centre console lid
gear shifter surround
ashtray
gear boot and surround
gearbox (manual)
all brake components
everything else still available
prices as follows
ENGINE NOW FOR SALE CALL FOR DETAILS
steering rack complete $400
diff $600
dash guage cluster $250 (auto cluster)
door sw plastic surround $35
climate controler $250
adjustable damper shocks $250 set of 4 (good cond)
springs 25mm lowered and 50% stiffer than stock $250 set of 4
standard castor rods(good condition) $150 pair
front quater panels $150 each (black)
ac pump $250
pow steer pump $250
pedal box $250
clutch master cylinder and actuator complete $250
all suspension components( wiishbones lower arms etc) call too many to list
email [email protected]
phone 0414 837 902
https://www.sau.com.au/forums/topic/78704-r33-whole-car-available-for-spares/
  • Replies 49
1994 r33 gtst
alraedy sold
engine
wheels
suspension
gearbox still in car
Hey mate, got a gtr spoiler with brakelight by anychance? (R33 :) )
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
