Originally posted by Strich9ine
look at all these people with mods tho.... hicks is pulling 13.7 (BEST)
and he's got 14psi, POD, full zorst, FMIC.. all that...
if you can pull a high 13 stock, why spend $2500 on those mods ?
hence my theory of not getting a stocker in the 13s....
Traction a big part of drag racing is the 60ft put some slicks on that sucker and watch the times tumble..
  • Replies 94
Originally posted by summoner
not much differance? go learn what mods do to a car kabab.. i woulda thought u'd have half a clue considering how long u been on forums. Exhausts.. especially on turbo cars help, not just by the better flow but by the inherent boost increase which comes with this better flow etc. So an exhaust is a decent mod for a car. put a stock exhaust on and see how asthmatic your car feels especially top end.
As kabab said, on the R33 GTS-t, you will maybe gain 1-2 rwkw by doing the cat-back section. This is because the restriction is found in the dump pipe, not the cat-back section. After going the dump, front pipe and 3" cat, I noticed a HUGE increase in power, but didn't notice any power increase at all when I bolted the cat-back section on.
Air filter was probably good for another 1-2rwkw...
So at that stage, I managed a 14.3 with a STOCK CAR (plus 4-6rwkw in mods)... Hardly earth shattering mods.
I have got a 13.8 sec pass with a mildy modified R33.
The conditions were as per the signature below. Namely 8psi ,over 100kgs in the boot + boxes of crap on all the seats and little 205's.
Having said all that my car is not stock (ie: it has mods). I don't believe the factory stock car could get past a flat 14 or 13.9 tops. If the stock turbo was taken to 20psi for one run (might take a few turbos before it did a run without blowing up) it might get a mid 13. Quite a pointless excercise.
Nissan slacked off on lots of areas from factory. Thus far the only mods to my car have been to correct the cheap ass inefficient parts. All the mods have added something to the power but not effected the fuel ecconomy exept to improve it.
Next trip down the 1/4 I'm trying for a flat 13 (with new clutch and light flywheel), big ask for the 205's but it will be fun trying.
Originally posted by predator666
Well it isn't "stock" then is it...every little mod makes a difference.
kabab, you've gone off topic.
Last night you said a bone stock R33 GTS25T can pull low 13s, no exhaust, no boost, nothing, except slicks.
Considering Andrew was trapping at 95mph, with a couple of very minor mods, a 93-94mph trap speed has no hope in hell of pulling a low 13 second pass, even on slicks.
You say most of the R33s you see are running low 14s with crappy 60 foot times, don't forget, most of the guys here are running modified cars, not bone stockers. Nobody above has the said car.
I dont think any of the guys here think its possible either. That is all :D
Argh, this is a frustrating thread, so much misstruth's flying around.
Firstly Elf fuel will only give horsepower if the engine is tuned for the fuel. And the fuel will probably stuff up your oxygen sensor and cat and perhaps even rubber fuel lines.
Also a quicker 60 foot time will improve your trap speed, which is kind of obvious. if you get off to a better start then you have more track to gain speed. That being said a "stock" (No exhaust no mods full stop) will be lucky to get into the 13s, however one with full exhaust pod and somehow tuned for the elf fuel, with slicks would go close to a 13.3
Bab out of all people you should know better.
Throw in a tank of ELF on a stock R33 and watch how crap it will perform without touching a thing. Mainly because of the high density of the ELF fuel, it burns much slower, so running standard timing and fuel maps will run rich and crap. The reason they retune for racing fuel is advance the timing to ignite the mixture earlier so it has time to burn and have it burn complete for more power. It will produce more power because there is a greater force on the piston earlier and at high rpm it will ignite the mixture before TDC instead of later (with ignition lag obviously). So whack slicks and ELF in a bog stock R33 and it will go worse than another on street tyres.
Id say most people with these times just need a bit more practice at drag racing...ive been my few times and hell its not easy to launc hright, anybody can drive down the track, but to launch quick and quell wheelspin (like Merli's learning!!!) is very hard and takes a long time to get it right...
but then Merli's 13.1 was still hell impressive so congrats bruddah!
Finally, someone agrees with me that ELF will be useless unless you can do something with it... then by modifying the ECU it will no longer be a stock R33 GTS25T :D
I agree, bring on a demo... im not paying.. not my claim to prove ;)
Well, its not stock either (bleed valve for 9psi, no zorst, no pod, nothing else), but I ran 14.2 the other day. That was running on R tyres, so they are a fair bit stickier than regular, but not full slicks.
Unfortunately we did not get 60' times so I can't tell you if they were good or not. Trap speed was 96mph.
But this does seem to suggest you could get high 13s in a stocker with a great launch. I could only go to about 4000rpm off the line without significant wheelspin, so there is probably time to be made with better tyres.
Originally posted by Shell
if you want to find out the time of a stock R33, my car is available :D
oh and my tyres are kinda due for replacement...does this count as slicks LOL :lol:
heh, she already offered. ;)
Sounds good Shell, wednesday week?
:burnout: :burnout: :burnout: :burnout:
exstaic ran a 13.8 with exhaust and s-afc running street tyres 10 12 psi I think mid 13's are possible may be a 13.4 babs is on the mark you dont need a bigger cooler unless you are fitting a bigger turbo in reality merli made reasoanble power witha stock cooler.
meggala
I ran a 13.9 at 101 mph at Eastern Creek on 4/12/2002. I have a sedan with 2 3/4 inch exhaust from cat back, pod filter with a cheap UAS partition and running 8psi. I can't run anymore boost due to spiking problems.
That day was really hot (36 celcius) and I had 5 runs. There was a group GTS T's together that day. During daylight none of us could break into the 13's or the 100 mph. There was 5 of us and we were doing from 14.1's - 15.1's at 93-96 mph. Would you believe as the sunset, these times did not really change ???.
On my last run after the sun had gone down I let my rear tyres down to 18psi, choose not to do a burn out as this only heats up the intercooler and ripped a 101 mph 13.9. I don't believe any of the other guys with GTS T's managed a 13 sec or 100+mph pass that day.
Unfortunately we were not getting our 60 ft times that day so I can't really compare 60 ft times to see whether that is where the difference was, although I'm pretty sure that the 13.9 would have been a result of a good 60 ft time.
Guest Skyline King
Guys.........
when TRY09s was 4ORCD (stock at first) it ran a 12.8 @113mph
it had a 3" exhaust ,pod filter,standard auto not manual,1 bar of boost and avgas and tolunene it ran those times with street rubber not slicks 1.8 60 foot.
exhausts make a HUGE difference to a skyline about 30-40bhp
and an air pod about 5-10bhp,most skylines don't like boost above 10psi as the ignition starts to detonate so hence the racing fuel,you can make 260bhp with these mods and tuning but as soon as you go back to std fuel and setup your looking at 140-160bhp.....hope this helps everyone....
thank you
mick
