Originally posted by Skyline King
Guys.........
when TRY09s was 4ORCD (stock at first) it ran a 12.8 @113mph
it had a 3" exhaust ,pod filter,standard auto not manual,1 bar of boost and avgas and tolunene it ran those times with street rubber not slicks 1.8 60 foot.
thank you
mick
The Auto was not stock. It had been tricked up with a 3000rpm high stall and shift kit. Its best was 13.4 @ willowbank http://www.autospeed.com/A_1050/page1.html
Unless you mod the stockie you are not going to get a very reasonable time, slicks or not.
Having said that the mods don't need to cost much to get you into a mid/low 13 in street trim should you want to.
I'd say if you scored the catback on your import from japan it could cost just a bit over $1000AUS for the mid 13 and just under $2000 for a low to flat 13. Regular 98 fuel and no slicks.
  • Replies 94
rev210 i think i know more than you about this car,.......
it was a stock auto no converter and it did a 12.8......don't belive what you read mate,some things are never right....
113mph terminal with only a pod filter, 3inch zorst and 1 bar of boost on a stock turbo?
Rrriiiiiiight...... (Quote Dr Evil) :P
What I find strange is.....
I was making ~150-155rwkw. on 12psi with an exhaust and AF's tuned using the Fuel pressure reg bleed kit.
Everything else was stock.
I had a run against Andy's R33 GTR which at the time was dead stock.
He had a 5000rpm clutch dump and I had a 4000rpm launch with not much wheel spin.
I held in front where his front was sitting at my rear wheel all the way through fourth gear.
Wouldn't this indicate a low 14 possibly even high 13?!?!
Also I had a Lightened Flywheel that was the only other mod.
I would take his word seeing as he probably did all the work to the car..
Hey Skyline King did it have stock ecu ?? i am asking this because i wanna know how much extra power you can get with stock by just using better fuel because most guys on here don't believe you can...
Thanks for your time..
So if you can run 12.8 with thoes mods listed a low 13 might not be out of the books with my setup...
Guest Skyline King
yes it had the stock ECU we turned the timing up alot as we used good octane fuel,REV210 believe it or not i'm only trying to help you guys in this topic and that is it's possible to run low 13's with a FAIRLY stock R33, i mean i have only devoted 6 years of my life understanding RB motors......so heck what would i know ( just a joke )
thanks
mick
Originally posted by red900ss
heh, she already offered. :P
Sounds good Shell, wednesday week?
:burnout: :burnout: :burnout: :burnout:
how about wednesday this week? It's new years day...and the way I'll be feeling, i won't really give a **** about what anyone does to my car :bahaha:
Kabab with cheese,
I think you might be able to do it.
Here is what I think you will need.
Slicks at the right PSI
No ELF but some octane boost/avgas/toluene to overcome our shit fuels
Remove your air filter.
Every ounce of weight out of the car.
You will need to change the suspension to at least handle a +4K launch. (But now we are not really a stocker!)
And the most important thing will be lots of practice and someone who really knows how to quarter mile. And I dont know if your the one Kababy boy?
But seriously what do I know about 1/4 mile, nothing! But my father inlaw is an old timer Drag racer, he did all the design work behind Dragway Mags, as his brother is the owner. He said the tyres and suspension and the two big things other than Horses.
joel your time would have been a high 13 I reckon . and yes I'm serious. but it can all turn to shit at the track. cause thats a different game.
love the 60' time skyline king is that when he was looking for a tougher trans afterward. 1.8 is quite a feat. but very doable
meggala
thanks
mick
Mick,
I appreciate that you worked on the car. Forgive me if I am a little skeptical due to the very high terminal speed. I'd love to be able to get that sort of terminal (as would anyone ) with so few mods.
I was under the impression that the stock ecu has a crap ignition timing curve. At least one not able to make too much use of the extra boost and octane. Did the car see any dyno around the time of the 12.8 / 113mph ? I'd be interested to know the result.
What brand/type of tyre was he running / mixture of tolunene / base idle timing ?
He didn't have an aftermarket intercooler did he?
I'd love to have a go and prove you right at my own expense.:P
Originally posted by Oz GTR97V
Kabab with cheese,
Cheese in kebab's is just wrong :)
With the suspension i my car i was taking off at 5500rpm and still bogging down.. so i don't think you would have to change suspension that much.. maybe just let the tire pressure down..
geeze after reading this entire thread i'd love to get my car out onto a drag strip and let it rip
Now if only their were no crowds or people around so that i could practice first coz i've never driven on a track before.
Originally posted by RB20LagWagon
Argh, this is a frustrating thread, so much misstruth's flying around.
Firstly Elf fuel will only give horsepower if the engine is tuned for the fuel. And the fuel will probably stuff up your oxygen sensor and cat and perhaps even rubber fuel lines.
Also a quicker 60 foot time will improve your trap speed, which is kind of obvious. if you get off to a better start then you have more track to  gain speed. That being said a "stock" (No exhaust no mods full stop) will be lucky to get into the 13s, however one with full exhaust pod and somehow tuned for the elf fuel, with slicks would go close to a 13.3
this maybe true? but EVERY run i have done plus all the runs i have seen my mates do have had bigger mph with crap 60 ft times eg my capri turbo run [email protected] yet ran a best time of [email protected] same day!
a COMPLETELY stock r33 gts with std everything as per the nissan factory i mean exhaust, filter everthing wouldn't do a 13 sec time, like someone else said some of you can't even run a 13 with mods so how u gonna do a low 13 stock? an auto r33 with full 3" exhaust, pod filter hks type, 12-14 psi, advanced timing and avgas will run a low 13 like a 13.2 or around this eg SUBZERO did it with try09? think it was? when it was mildly modded!
mick, how did you get a 1.8 60ft with the std auto? my gf's s14 auto's best was 2.16 for the [email protected]. for this i had to sit on the line and get it to just turn the tyres (boost) then go, reaction times were like 2.5 secs! a mate of mine run 12.8 @106mph in his auto z with similar mods to 4ced except it was optimax & nos octane booster!
I was looking around at a few web sites today and stumbled upon a Skyline Info page.
They said the R33 would run to 100km's in 6.2 secs where as the R32 would run in 6.3 secs.
Don't really know where they got those times from.. Apparently they were the official times from nissan.
I'll have to dig up the link if my history is there. Damn history is gone.. :)
i only just read a post on here that says...
look at all these people with mods tho.... hicks is pulling 13.7 (BEST)
and he's got 14psi, POD, full zorst, FMIC.. all that...
if you can pull a high 13 stock, why spend $2500 on those mods
firstly, if he spent $2500 on all that it must be mega **** gear, and if its legit and he can only run 13.7 something is drastically wrong
.....stock r33 gtst, you would have to be a very f ****n awesome driver to get into 13's, im talkin no nothin, pod, suspension..nothin..ive got an r33 with a few minor mods and its quick but some people dont realise what it actually takes to run a good time...
eg, all those vx clubsport pieces of trash, think theyve got the quickest car in the world, claimed around low 14s stock, u watch all the heroes on the track and they r lucky if they get into the 14s...ive seen many 16s even
stock..the best u could hope for is a high 13..on a cold night, i wish it was quicker though....
Remember its not just all about 1/4 times. Its also about the seat of the pants feel.
Personally I'd rather a really quick car on street tyres, some thing quick 0-100.
I think just over 200rwkw is a good power level for the street much quicker and you start having to spend to much on tyres and to much worry about wheel spin.
200rwkw in a 32 with stock suspension will pull a low 13 anyhow.
Which is getting damn close to the 300k Porsche Territory.
Very similiar power (20-30rwkw) but the porche weighs an extra 300kg's.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
