ed Posted June 29, 2005 Share Posted June 29, 2005 The new emanage is out now. Check it out here...http://www.mohdparts.com/emanage/tmp/ultim...spec/index.html A few features that will appeal to most are: A/T Shift Compensation Feature - On vehicles with Automatic Transmissions, ignition timing can be compensated at set shift-up and shift-down points A/F Target Value Map (feedback tuning function) - By inputting target Air Fuel values in this map, “e-mange Ultimate” will automatically make corrections to the “Injection Map,” if an A/F meter (*high quality) is connected to the Auxiliary Output signal. This feature can shorten the tuning time. Acceleration Ignition Map - Ignition timing can also be corrected for a rapid change in the throttle opening rate for a smoother transition into wide open throttle Fouled Plug Feature - When initiated this feature can help clean fouled spark plugs by cutting the injector’s firing at start up. To fix the fouled plug start the engine with wide-open throttle. Speed Limiter Cut Feature - This feature will eliminate the factory speed limiter. (May not work on some vehicles) Knock Monitor (Future update) - Knock can be monitored and reviewed. Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/ Share on other sites More sharing options...
Abo Bob Posted June 29, 2005 Share Posted June 29, 2005 Ooh. Sounds interesting. Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/#findComment-1436732 Share on other sites More sharing options...
Steve Posted June 29, 2005 Share Posted June 29, 2005 Some nice features, I wonder how much more than the standard e-manage this one will cost. Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/#findComment-1436757 Share on other sites More sharing options...
JaFF Posted June 29, 2005 Share Posted June 29, 2005 hmmm I spose I should do a search but how does this new model compare to a powerfc? Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/#findComment-1436796 Share on other sites More sharing options...
TimmyC Posted June 29, 2005 Share Posted June 29, 2005 considering it only just came out i doubt a search would yeild (spelling?) any threads comparing the two Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/#findComment-1437104 Share on other sites More sharing options...
ed Posted June 29, 2005 Author Share Posted June 29, 2005 hmmm I spose I should do a search but how does this new model compare to a powerfc? You'll be comparing a piggy back to a standalone. The MAJOR up side to this is that it claims to work on auto cars with the timing problem resolved. So auto owners will want to look in to this. Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/#findComment-1437113 Share on other sites More sharing options...
666DAN Posted June 29, 2005 Share Posted June 29, 2005 Prices are here http://www.mohdparts.com/emanage/ Would be $900 delivered to Aus for the e-manage plus the harness kit + software...also this guy is one of the best suppliers around, efficient and reliable and sends everything via UPS tracked. Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/#findComment-1437129 Share on other sites More sharing options...
Cubes Posted June 29, 2005 Share Posted June 29, 2005 Definitely good for the Auto boys. Never know.. If I blow this manual I 'may' look at a tough 4speed auto with a mild stall. Should work nice with the 3ltr. Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/#findComment-1437561 Share on other sites More sharing options...
Abo Bob Posted June 29, 2005 Share Posted June 29, 2005 Should be cheaper to tune than anything else if it works as advertised. Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/#findComment-1437708 Share on other sites More sharing options...
rob82 Posted June 29, 2005 Share Posted June 29, 2005 So let me get this right, it has direct control over the injectors? Also how the **** does it indivually tune the timing does it have direct sequential control over the ignition as well. And if it does do have control over both than why not just do away with the standard ECU? Maybe I'm interpretting it wrong. Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/#findComment-1437808 Share on other sites More sharing options...
ed Posted June 29, 2005 Author Share Posted June 29, 2005 So let me get this right, it has direct control over the injectors? Also how the **** does it indivually tune the timing does it have direct sequential control over the ignition as well. And if it does do have control over both than why not just do away with the standard ECU? Maybe I'm interpretting it wrong. Maybe it is like the HKS FCON PRO where it uses the stock ECU for cold starts, air-con etc... :crazy: Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/#findComment-1438080 Share on other sites More sharing options...
Chase-u Posted July 8, 2005 Share Posted July 8, 2005 so is that $900 including all the bits and pieces or $900 and then harness and software on top of that? just confused Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/#findComment-1454403 Share on other sites More sharing options...
hoo@h Posted July 19, 2005 Share Posted July 19, 2005 so is that $900 including all the bits and pieces or $900 and then harness and software on top of that? just confused just orderd mine from perfectrun.com.au. The unit itself is around AU$730 which include software and the complete harness set is about AU$112, and yet to find out how much the shipping cost is. Now just need to find where I can get it install and tune in Brisbane area. BTW, there's no english translation for it yet, because it's new item, but the guys at perfectrun told me if I can fax them the wiring instruction. They will be happy to translated it into english. Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/#findComment-1473994 Share on other sites More sharing options...
Abo Bob Posted July 19, 2005 Share Posted July 19, 2005 Have you got an auto or manual? Keep us informed. Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/#findComment-1474109 Share on other sites More sharing options...
hoo@h Posted July 20, 2005 Share Posted July 20, 2005 Have you got an auto or manual? Keep us informed. I got an auto, that's the reason I jump on this new emanage unit, now I am hoping it will work well. I will keep you guys posted when I get it and have it installed. Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/#findComment-1474755 Share on other sites More sharing options...
Sydneykid Posted July 20, 2005 Share Posted July 20, 2005 $730 + $112 + freight + 10% duty + 10% gst = ~$1100 That's as much as a Power FC On the Stagea I used a Jaycar DFA $80, Controller $70 and an SITC $210 = $360 And I don't have to work out my own mapping for gearshifts as the SITC doesn't change the standard ECU logic. Pop over to the Stagea section for progress to date and ongoing results:cheers: Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/#findComment-1475177 Share on other sites More sharing options...
craz0 Posted July 20, 2005 Share Posted July 20, 2005 Nengun has them listed as well, will be very interested to see how this goes:D Link to comment https://www.sau.com.au/forums/topic/78717-new-e-manage-ultitmate/#findComment-1475306 Share on other sites More sharing options...
