*Price Drop* Only asking $7k negotiable now
Putting this up to see if I get any interest, am going to sell soon due to finances as I wont be working full time in a few months.
Its a 1989 4 door GTS pillarless with a stock redtop rb20det motor, R33 automatic transmission.
Has about 95000 genuine Kms on the clock at the moment, was imported back in 1994.
Engine is stock aside from full 3inch Exhaust system (dump to cannon) and Pod intake filter.
Aftermarket Boost and Oil Pressure guage (runs about 10psi with the exhaust system)
Clarion 6 stacker audio system
has 15/65/205 rims (not sure what type) Good tread
The turbo was rebuilt when the previous owner had it around 60k kms
Just had the timing belt and water pump done, major service etc, brakes machined.(Have reciepts)
Coil packs have been replaced recently.
Cyclops immoboliser and alarm system
Has had oil changed every 4000kms
LSD diff - no whine or clunk
Has about 4months rego left
Only issues are dent in sump and the O2 sensor needs to be replaced, dent has been there since the previous owner bought it.
Body is in great nick, no dings or rust that I can see. Interior is also in good nick. Comes with the usual power windows, adjjustable suspension etc.
Here are some pictures taken earlier in the year, Im asking around $7k but as I said its mainly just to see if I get any interest at this price, also If I do sell I am going to buy a piece of shit for about $300 to get around in till I find something I like so if you have anything like this Id happy take a couple hundred off the price.
I will check this thread regularly so if you have any questions please post, my phone number is 0423277771
SkylineGT Pic1
SkylineGT Pic2
SkylineGT Pic3
SkylineGT Pic4
SkylineGT Pic5
SkylineGT Pic6
SkylineGT Pic7
Edited by Rolls
Sale fell through, buyer couldn't come up with the money.
Back up for sale, will be going in the trader next week but would prefer to see it go to a R31 enthusiast then some dick whos just going to thrash it.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
