  • Replies 63
you gotta have fully sick spray tags. Nothing says leet than a mad spray tag. Especially the ones which look like ladders or the enemie :P
hehe I reckon the porn ones are more distracting!!
Turn around a corner and some naked chick has her legs spread and looking at you!!! then bang! (that happened to me once....hehe)
ok what time do people play???? maybe we can all get on the same time??
if i get time to it's about 10 to 11 on a week night or 7-8 ish in the morning on a weekend.
i've thought about having a server, but one of my mates had one for a while and it costs a bit to keep runing, plus it's time and energy he wasn't willing to endure for more that 2 months. I don't think i could be arsed either.
I'm definatly up for an SAU showdown however... hehehe
man i miss the CS days
they were da best, junk food and LAN meeting thats da 5hit
Yeah, that brings back good memories....playing late at night till the early hours of the morning, even got the g/f to play CS on occassions against a bunch of other girls on LAN, they get into & are alot more verbally violent :ak47:. My alias' used to be 'ICEMAN' & 'BLADE', might have to try join u guys somethime.
ahhhhh good old CS 1.6
the best cs ever (with fusion pack 10 mod)
i still play everynow and then - but never online
St33_ft owns ever bot on every map (woohoo go me)
just remember to make shopping easy:
b82 b84 b13 b31 (buys kevlar and helmet, then grenade, then desert eagle then mp5 navy)
i always use this combo of weapons when i first start a game until i get more cash - then i usually go the aug or the m4a1 or the scout or cut sick with the machine gun
have fun and p3wn every body and every bot
damn..... got on for about 5 minutes, but had to leave..... couldnt find the particular server you guys were on as not being an optusnet player usually i didn't realise that there are about 10 or so servers.
maybe we should get the numbers up and arrange a specific server and time....
i'm still keen :)
give you some tips.
when using m4 or ak only fire in 3 shot bursts and the realign ur aim. Always aim for the neck or head.
Always keep your guard up. Most people get killed cuz when they are running around their aim height is at an opponents feet/legs.
When you strart a round, get your aim height off of your team mates head/neck. least then you'll know you'll be at the approximate height of your opponents head/neck :P
uhmm stop and listen sometimes. sound is almost the most important thing in CS.
will post some more later but i gotta go.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
