newy unleashed cruise 23rd july
newy unleashed
 Share
Sponsors?!?! :P:) :)
Yeah, I can understand how "sponsors" would be THROWING money at a 15 year old who doesn't have a licence :)
Your "car club" has 4 threads on it, 3 of which were started by you :Oops:
we got sponsors interested in dvd and they givin us wat we need so it dont bother me that u bag us out
guys we are 15 so i think we doin alright
english??
The very fact that you are 15 and you are putting together a DVD with "sponsors" involved is very questionable... how did you get the capital to start such a venture? Furthermore, would a well established company with a reputation to worry about invest money in a venture started by 15 year olds and risk being the laughing stock of everyone who knew about it?
You may have a lot to speak for, but at the moment it just ain't too credible
good to hear you have a great turnout.... count me out though. got better things to do, cars to see, people to meet and tyres to destroy on that weekend.
thanx man
atleast some people have an idea on how hard it would be to do all of this as a 15 year old
Don't use your age as an excuse expecting people to be thankful that you are doing this! From what most posts you've made here suggest that you'd like us NOT to consider your age. Then you go claiming that its so hard to do all this "as a 15 year old". You gotta find one argument and stick with it.
Now in regards to this event, its a good plan/suggestion and i hope the day goes well. I won't be attending, but im sure the cruisers should have a good day.
May i ask who are the sponsors and when/where i could look at the finished dvd?
:matrix:
:boobs: i know this maybe a bit harsh!!! but did someone get a video cammera for there 15th birthday. come one unleashed who are the sponsor's and why havent you gave them any credit for this, by putting there name up on this sh#t hot event of your's.
that's a first for me to see a dream team up in running one week and then making a dvd in 2week's time . well done unleashed good effort. good luck hehehehe
 Share
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
    • Yeah, so try to post images with extensions that the internet can handle, not HEIC files which only arstyphones can handle.
