Bought these a couple of years ago, never used.
The carbon thing fits around the hood latch, between the grill and radiator. Carbon fibre top layer, fibreglass underneath. $100
Greddy clear timing cover, replacement on RB26's - $150
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
