I have 2x7 Inch TFT LCD's that are for the headrest of your vehicle.
Come with the mounting brackets so will go on ANY car.
Perfect, clear picture, good for DVD players, PS2 etc and will keep your rear passengers and cars behind you entertained.
As new, hardly used, i have no use for them now as i have changed the headrests.
I am in Sydney.
$270ono
https://www.sau.com.au/forums/topic/78784-2-x-7-inch-rear-headrest-tvs/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
