hey guys on my Gts-t R33 my Green hicas light is on on my dash whats it mean i know
Its like nissan All wheel steering or something but is the light meant to be on all them time whats the go
Alsome boost starts at like 2400Rmp on my car is that Good i think thats pretty low
what does a HI flow turbo kit do
I wood like to get a little more Boost later down the Track
Atm it has
Front Month Intercooler
3" Cat back exhaust
Turbosmart BOV
Link Computer
K&N Pod
Its only making 140rwkw on 7psi
I am thinking Get Dump and Front Pipes & Cat that should make the power its
Missing
Cold air Box for Pod
Up boost
later rebuild turbo with Hi flow Kit how much and what do they do when it dies
https://www.sau.com.au/forums/topic/78790-green-hicas-light-hi-flow-turbo-kits/
  • 3 weeks later...
hi scott
if you want more boost then just get a boost controller. you dont need to change the turbo to get more pressure through it. you can get a cheapie bleed valve for around $50 or you can get an electronic controller 2nd hand for $250 odd ish. electronic is better of course. you can run upto 10-11psi on the stock turbo fairly safely. that should bump your power up a little bit
