redline or motul oils
GtstCoupe
 Share
im about to do an oil change in the following ,diff ,box and motor and am wondering what to use i only want the best for my car, and can you recoment what type to use and how much i will need,
thankyou one again :P:D;):P
I use motul
The litres i used were for a 4wd gts4 r32
motul 8100 excess for the engine about 4.3 litres with filter
pick up a ryco z145a or valvolie equivalent
motul gear 300 for the box (4.2) and front differential (1.2)
motul ff-lsd for the rear lsd (1.6)
If your changing oils under car you might aswell change the tranfer case the r32 recommends nissanmatic d
 Share
