OK IV GOT THESE RIMSFOR SALE 18"
they are of a vspec gtr limmited edition 18" BBS RIMS
only 3 rims front 2 and 1 rear
a few scratches and rear rim has discouloration due to heat rims spin true with no warping
all you need to do is find the other one and you will have a great set of rims
asking $880 ono they look awsome
im not sure how to post pics so email me for pics at
[email protected]
or 0412569336
https://www.sau.com.au/forums/topic/78871-fs18bbs-gtr-vspec-rims-no-tyres/
