hey
my thermo died so it had been replaced but the car is now running much cooler then it originally was, these days its lucky to get upto 70deg (damn winter) whilst it was originally running at approx 85 deg. can this cause
bad fuel consumption ?
loss of power ?
engine damage ?
i'm just wondering cause i was looking at the water temp correction tables in the PFC and noticed that the only place where its set to 1.00 is at 80 deg +++
but if my water temp doesn't reach 80deg + then it'll always be treating the engine as if its still warming up..... should i get the thermo adjusted or can i just set the settings in the PFC to 1.00 for water temps at 60 deg +
also in the correciton tables there are 2 columns i assume one is for A/C on and the other for A/C off, but am unsure....
please help :confused: :confused: :confused:
https://www.sau.com.au/forums/topic/78873-can-an-engine-run-too-cold/
Most thermos do not cool as well as the standard clutch fan. After people install thermos, they usually notice that the temps run hotter.
Therefore, you're setup should be alright, because if you were running the stock fan, it would be even cooler (that is, assuming that you have the same setup - i.e. it switches on at the same temp etc).
Your best bet is to re-calibrate your thermo fan controller to turn on later and keep your water temp between 75-85degC
Anything less and really it just causes engine wear and tear.
I would be looking to run 1.00 or no extra fuel anything above 70degC, anything below this and it will require extra fuel for smooth running.
well i had a fiddle with the PFC, turned down the 50 deg value in the PFC, seems to be runnign ok, its hard to tell nowhere to get up into 4th gear and wheelspin city thru 1,2, and a bit of 3, so hopefully tommorow will be cold and dry and we'll see, how can i find out how the thermo is set ???
got up to 70 deg quickly tonight on the way home and hovered there not until i put the boot in (3 short boosts in 3rd) did it start to climb and only upto 74 deg, then slowly dropped again......
Most definitely yes.
All metals expand. Aluminium-alloys much more & faster than iron-steel. All engines are machined to calculated clearances for the material composition of the components, so running cool it will not allow enough expansion & most components will wear faster. Also, most alloy headed engines produce maximum power between 82 - 90 deg. c. This is ofcourse as long as the gauge is accurate & measureing the temp. of the water exiting the head. Don't confuse low engine temps. with low charge air temps.
    • We are taking pricing back to 2022! The skid pan is nearly double the size of avalon so much better for longer battle runs as seen here > https://www.youtube.com/watch?v=ANxdRf3Do2s When: Saturday 14th June 2025 Where: Winton Skid Pan (Winton Motor Raceway) Price: $145 for SAU VIC Members            $199 for non Members Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to motorsport@sauvic.com.au or print and hand in and Driver Sign In. email motorsport@sauvic.com.au To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and it is reccommended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs on the enty link. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Accommodation:  In an effort to try new things and support other country towns we thought a new location for accommodation was worth trying and Euroa was great last time plus its 30 minutes closer to Melbourne. Saturday night we will book a spot at the pub for a couple of quiet drinks.......   Book your accommodation ASAP before it sells out, there are also other options in town if you want to stay elsewhere and join us for dinner Saturday night.   https://euroacaravanpark.com.au/ Address: 73-103 Kirkland Ave, Euroa VIC 3666 Phone: (03) 5795 2160 Entry link with Full Supp Regs to read: https://www.sauvic.com.au/entry/deca/20250614 Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email motorsport@sauvic.com.au Entry List: 1. Josh M 2. Anna 3. Luke  4. Katie 5. Martin 6.  7.  8.  9.  10.  11.  12.  13.  14.  15. 16.  17.  18. 19. 20. 21. 22. 23. 24. 25. 26. Reserve List 1. 2.
    • Yeah, playing with naturally aspirated is not smart bang for your buck power wise, but then I've never been known for being smart when it comes to cars and modifications
    • I mean from V8 world there are gains to be made in intakes and such over stock items, but definitely only if you tune them. We're talking about I dunno, 10kw here and there on a 300KW v8, gains made by tuning in the 0.2 AFR that it changes so YES but also no you won't notice it other than the sound. Duct the air as mentioned 750,000 times and you will notice happier IAT's which definitely make a difference N/A. I mean my unsubstantiated guess is you'd go from 140kw with everything stock (after cams) to 145kw with everything and a tune :p
    • I decided to "spend baby spend", and "risk it for the biscuit" 2 Orders were made buying parts that I "don't really need but really really want" totalling $2.5k AUD 1: In stock items (intake plenum and throttle body) 2: The airbox thingie, with no real ETA for them getting more stock, so patience will be required
    • Any further updates on experiences with them? Anyone installed one with a getrag here as yet?
