Hi Guys,
I've got a Nissan Skyline R33 Series II to sell for cheap!!
SPECS:
Nissan Skyline GTS-T, R33, Series II, RB25 Turbo, Black, Dual Air Bag, ABS, 55000 Km, Sunroof, Tein HA Coilovers, Sony Deck with CD Stacker, Remote Alarm.
Will sell Tein HA Coilovers separately, gimme an offer.
I'm asking $13000 for the whole car or near offer.
PM me for pics.
Note: Car cannot be registered, can only use for wrecking or race car.
Cheers.
https://www.sau.com.au/forums/topic/78874-cheap-r33-sii-13000-must-sell/
