Hey Guys,
I've spoken to my boss who wants to do a deal for Skyline Owners...
I work for 2 for 1 Window Tinting on the Gold Coast located at Ashmore and Burleigh.
How Does $160 per Skyline Sound?
How Does $20 extra if we have to remove existing window tints?
Only $20 extra for the 4 door skylines
Please PM for information on tints available. :)
All tints must be done on a Saturday, however we might be able to (depending on interest) tint some cars during the week. All cars must be tinted in groups of 5- or more on the day. We will offer this deal over several Saturdays with dates to be finalised depending on interest.
All Skylines owners must PM me for this deal to be honoured.
P.S - Our Design Team are specialists in creating custom graphics to individualize your car.
You can visit our web site at: http://www.2for1windowtinting.com.au/
Thanks Guys, we look forward to meeting the skyline community :P
P.S - I will reply to all messages via PM.
EZYTGR
https://www.sau.com.au/forums/topic/78876-160-for-skyline-window-tints/
Hey,
We apply the film to the glass, and trim the edge as required.
The gap of natural light above the tint on the glass edge is almost non-existent. If you would like to see our quality, please stop by at any stage to see for yourself.
I know what you mean by variances - Other companies have been known to grind the excess tint off, both damaging the glass and causing imperfections in its sealing ability. I have also heard of other companies pre-cut the templates with 5mm of natural light showing at every edge, Cutting the time frame down but it's looks very dodgy.
P.S - Frameless glass is no problem.
Thanks
  • 5 years later...
quick / noob question
i got that crappy purple colour tint on the rear window which is peeling. looks horrible. Does it make a difference removing the tint with the de-mister / heater wires (not sure what you'd call it) that are on the rear window?
very keen on tints
Quick heads up to teh noobs...
last post was in 2005... i don't think he can fit you in unless your delorian skyline can travel back in time
and louie.. check the dates before you search for ancient shit eh...
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
