Hi Guys
Ive imported a fully approved 15 year old R32 GTST which now sits in my shed. Does anyone know if you have to have the car engineered complied and registered within a certain amount of time once its in the country.
I intend to do the work my self including other mods but dont want to got through Engineering cert and rego until 12 months down the track.
Cheers
Mad
https://www.sau.com.au/forums/topic/78878-compliance-time/
Hi Guys
Cheers
Mad
bump :confused:
https://www.sau.com.au/forums/topic/78878-compliance-time/#findComment-1439435
I don't think there is a time limit.....but with these new laws...I have no idea. Worst comes worst, you'd have to comply/register by January 2006 at the earliest (that's when the new importation laws are enforced) don't know how that will effect compliance regulations...
One of my mates has an early model 89 model GTR in his garage, still hasn't complied or registered. I know there no exact time frame that is given once the car is in Australia.
https://www.sau.com.au/forums/topic/78878-compliance-time/#findComment-1439881
Mad Murf,
No time limit at all for when it has to be signed off, but if rule changes come in saying who has to do the work it is the only hitch you might get, you only have 30 days to register after passing inspection.
I will be at Technical Section at the pits on Monday and I will get a answer and post it for you, remind me still as I have a lot on.
After I get correct info I will give you details of who to get it in writing of if need be.
Nigel.
[email protected]
https://www.sau.com.au/forums/topic/78878-compliance-time/#findComment-1443454
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
