hey,
When driving my R32 GTR it keeps cutting out (similar feeling to running out of fuel) and when it does this it wont idle it just stalls, then ill start it again and it will idle ok and drive normally for a bit (seconds to a minute or so), then start cutting out again
the feeling when it cuts out at say 2500rpm is very similar to running out of fuel in your tank but a tiny bit different, runs really rough like its dropped half the cylinders and looses all the power completley. its not persistent tho and when it comes good it runs perfectley for a little while (enough to limp home on).
my guess is its a fueling issue of some sort, has anyone come across this problem before?
https://www.sau.com.au/forums/topic/78895-r32-gtr-stallingcutting-outhelp/
the ignitor module does look a little corroded on the outside, ill take a better look at it
Hey i got the same problem with my 33, but my one is from 3000 rpm travelling at an average st speed, pop it to neutral then the idle jst drops down as if its gonna stall then at one - three times it did stall, but wen i put it back to gear it started running again =S
i have an r32 89 rb20, and yes it is an auto. It had sort of the same prob. kept stalling on me, it still does. but yeah cruisin down the highway it would just cut out...and the kick back in and be fine. The other day it just kept stalling and when it would idle i would try and rev it, when it got to 2500 it would hit like a rev limiter and just back off..and then it would stall. So i would let it sit and it would be fine. But does that explain why it wouldnt do it all the time, and would it be why it does it when i am going down the highway??
EDIT: Someone suggested it could be the crank angle sensor....but the air flow meter sounds interesting....i reset my ecu and it was good for the rest of my trip, so that might be a temporary solution.
Hey i had that before, but i fixed it now, its really quite simple if you dnt know where to start. Firstly do you have an aftermarket BOV? Rev it to 4-5000 rpm then check if the engine is about to die, do it for a cpl of times. If this is the problem then jst swap ur stock bov then try it again if it doesnt fail its definitely your BOV.
It could be alot of things but i know the GTR's have a limp mode built in to the ecu programming. That will limit the revs to 2500 if sumthing is wrong...
Yeah man thats what my importer said. Yeah but sometimes it does not just limit the revs but like cuts out at the 2500. and sometimes it will limit it. I wiped my ecu and it still does it though. So has annoyone got any other ideas.
Lang: In simple mans terms, the loose wiring in the loom...where do i find the loom? :S
the loom is the wiring loom which afaik just means all the wires that go from the ecu to various parts of the engine bay, allthough i think in my case (a freind fixed it) it was to do with the wiring from the airflow meters to the ecu.
ok thanks you
  • 4 weeks later...
I have a very similar problem
the car stalls "randomly", especially after I hit bumps.
monday, I went slowly into gravel, turned the car off, started it, and went about. 15 secs after.. engine died and didn't start again after 5 tries, Fuel pump was priming so that wasn't the prob. I have a recirculation BOV so if it leaks, it goes in behind Z32 MAF. I tried following the wire loom from the connector and it passes right under the A/C oil canister... and the loom was somewhat filled with old oil.
I will for sure to to follow that cable tonight and make sure everything is secure and undamaged.
My car is not in limp mode, I can go to redline with no trouble and with quite a bit of power.. if it's not acting up hehe
I do hear misses at any rpm range... like Highway... at 3000 it will do it but for like 1/2 sec and the engine "starts" back. I will also clean the MAF tonight with electircal contact cleaner
and verify every air path :P
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I can do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not! It's well within the service manual specs...but they are very open
