Hey guys,
I have a kicker 400.1 class d subwoofer amp, the amp has recently been running off a 7892E alpine head unit, and was fine, not long after i took it out because i took the head unit out (nothing strange happened still was working)
Now i've gone to hook the amp back up, and it keeps going into protection mode, then flashes 'on' and back into protection mode, the amp will not power up.
Does anyone know what i would look at to see whats up? The fuse isnt gone either, its just strange that its done it all of a sudden.
Thanks
Dayne
https://www.sau.com.au/forums/topic/78905-protection-mode/
Check the main fuse near the inbetween the power cable to the battery(the large one), the one in my amp kit looks absolutely fine, no broken fuse or anything but.......
Still didn't work, i removed that fuse to see what happens, and it instantly worked!! So it was a faulty fuse that didn't look faulty at all lol....shitty fuse perhaps?
https://www.sau.com.au/forums/topic/78905-protection-mode/#findComment-1448604
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
