The best service and quality in MELBOURNE mate..
Imperial Finish
Centre rd
Springvale
Ask or Murray.
Your welcome to see his work in the flesh.anytime.See below.
Cant speak more highly of him as the car below was a sad state of a car before Murray got hold of it.Price is very reasonable to.
Imperial Finish
Centre rd
Springvale
Ask or Murray.
car looks nice man!
is that your car? so they will fit and paint aswell?
... btw, i like the rear clear tail lights!
car looks nice man!
Hey Flex
Car belongs to a far younger and 50 kilos lighter guy than me Flex.I found his car in the garage hidden under sheets not moved for a few mths.Damaged front bar interior lets say missing and the boot contained only acid were the battery had leaked.no carpet at all mate.EPA letter attached to it everything illegal you could shoe horn on to one car this thing had two of.It went very average so Fool here said give it to me and I will turn it into something you wont hide under sheets.
What you see is what ive just completed as my first attempt in the car mod game.I will now retire as it is bloody hard.I wanted the car to be differant from a boy racer look with the big baked bean can exhaust and monster tachos etc so reason for the diff lights..plus we wanted to get it going to its optimum.
In answer to the body repairer this r33 as all cars murray fully paints was stripped completly body kit front,rear and quarter panel windows.They are great fit and painters.
couple more pics below flex.
Cheers mate .
Imperial Finish
Centre rd
Springvale
Ask or Murray.
whats the number for that place mate??? i wanna take my car there to get a kit fitted and resprayed after the panel beaters have finished with it. ( panel beaters that are workin on it do a shitouse paint job, so i want a good one :O )
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
