CUSCO OIL CATCH TANK, BRAKE STOPPER, TENSION ROD BAR, STRUT BRACES ALL in STOCK NOW!
  • Replies 63
S14/S15 UPPER FRONT STRUT BAR - SOLD OUT!
CURRENT STOCK
- OIL CATCH TANK 15mm hose, (suit all nissans) $169.95 (free delivery or pick-up)
- BRAKE CYLINDER STOPPER
* RS13, RPS13, PS13 S14 - $119(free delivery or pick-up)
* S14, S15 - $119 (free delivery or pick-up)
* BNR32, HCR32, HNR32 - $149 (SOLD OUT)
* BCNR33, BNR34 - $119 (free delivery or pick-up)
* ECR33, R34 - $149 (free delivery or pick-up)
- Upper Front Strut bar - Type OS (suit S14, S15) - $249 (SOLD OUT)
- Upper Rear Strut bar - Type OS (suit S14, S15) - $249 (free delivery or pick-up)
- Upper Front Strut bar - Type OS (suit R32. HNR32, BNR32) - $249 (free delivery or pick-up)
- Upper Rear Strut Bar - Type OS (suit R32. HNR32, BNR32, A31, C33, CA31) - $249 (free delivery or pick-up)
- Upper Front Strut bar - Type OS (suit BCNR33, BNR34) - $249 (free delivery or pick-up)
- TENSION ROD BARS
* RS13, S13, RPS13, PS13, S14, S15 - $149 (free delivery or pick-up)
* HNR32, BNR32, HCNR33 - $149 (free delivery or pick-up)
Does the Oil Catch Can come with instructions?
Also, the brake cylinder stopper... is the movement you're talking about causing my car to swerve slightly when I come to a hard stop? Will this product fix it up? Is it a direct bolt on to the R34 GTT?
yes it comes with instruction in japs though :D
The BCS basically keep the brake master cylinders from moving. Using Cusco’s Brake Cylinder Stopper, the unwanted flex of the brake master cylinder is prevented when the brakes are applied. Due to the high forces exerted against the bulkhead under braking, the Cusco Master Cylinder Stopper bolts upto the end of the master cylinder and vastly reduces bulkhead flex which in turn leads to a better brake feel.
yes it is direct bolt to R34. :P Pm me for more details mate..
CURRENT STOCK
* 180sx, RS13, RPS13, PS13 S14 - $119(free delivery or pick-up)
- TENSION ROD BARS
* 180sx, RS13, S13, RPS13, PS13, S14, S15 - $149 (free delivery or pick-up)
one cusco oil catch can sold today!
Popular question:
i often get asked whats the different between kit specific oil can and universal one
i sell the universal one only. and honestly there is no different. in fact the universal kit is better in my opinion as you are not retricted in the area that you want to mount it on.
whereelse the specific one, you need to mount only in that particular area.
the universal are good as if u decided to sell it away, you can sell it to anycar instead of the specific to the type that you have. eg an s15 specific oil catch can only fit to s15 car and nothing else.
the universal are easy to fit on as cusco mounting are designed in such a way that they are very eesy to put it on as you can see from the pics below.
hope that helps :D
1 cusco oil catch can
1 tension rod bar 180sx
1 cylinder brake stopper
SOLD TODAY
CURRENT STOCK
________________
* RS13, RPS13, PS13 S14 - $119(free delivery or pick-up) x 1 lLEFT
* S14, S15 - $119 (free delivery or pick-up) X 1 LEFT
* BNR32, HCR32, HNR32 - $149 (free delivery or pick-up) (SOLD OUT)
* BCNR33, BNR34 - $119 (free delivery or pick-up) X 3 LEFT
* ECR33, R34 - $149 (free delivery or pick-up) X 2 LEFT
- Upper Front Strut bar - Type OS (suit S14, S15) - $249 (free delivery or pick-up) (SOLD OUT)
- TENSION ROD BARS
* 180SX RS13, S13, RPS13, PS13, S14, S15 - $149 (free delivery or pick-up) (SOLD OUT)
* HNR32, BNR32, HCNR33 - $149 (free delivery or pick-up) X 2 LEFT
s13 cylinder stopper SOLD OUT
CURRENT STOCK
________________
- OIL CATCH TANK 15mm HOSE (SUIT ALL NISSAN) BRACKETS INCLUDED. $169.95 (free delivery or pick-up)
* RS13, RPS13, PS13 S14 - $119(free delivery or pick-up) (SOLD OUT)
- TENSION ROD BARS
CURRENT STOCK
________________
- BRAKE CYLINDER STOPPER (A MUST ITEM FOR YOUR CAR!)
- TENSION ROD BARS
* HNR32, BNR32, HCNR33 - $149 (free delivery or pick-up) X 1 LEFT
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
