  • Replies 63
do you deliver to melbourne as well. im interested in oil catch can
yes. free delivery aussie wide for any product purchased. not only that. i throw in free registered post to ensure the parcel arrived safely! :)
S14/S15 UPPER FRONT STRUT BAR - SOLD OUT!
CURRENT STOCK
- OIL CATCH TANK 15mm hose, (suit all nissans) $169.95 (free delivery or pick-up)
- BRAKE CYLINDER STOPPER
* RS13, RPS13, PS13 S14 - $119(free delivery or pick-up)
* S14, S15 - $119 (free delivery or pick-up)
* BNR32, HCR32, HNR32 - $149 (SOLD OUT)
* BCNR33, BNR34 - $119 (free delivery or pick-up)
* ECR33, R34 - $149 (free delivery or pick-up)
- Upper Front Strut bar - Type OS (suit S14, S15) - $249 (SOLD OUT)
- Upper Rear Strut bar - Type OS (suit S14, S15) - $249 (free delivery or pick-up)
- Upper Front Strut bar - Type OS (suit R32. HNR32, BNR32) - $249 (free delivery or pick-up)
- Upper Rear Strut Bar - Type OS (suit R32. HNR32, BNR32, A31, C33, CA31) - $249 (free delivery or pick-up)
- Upper Front Strut bar - Type OS (suit BCNR33, BNR34) - $249 (free delivery or pick-up)
- TENSION ROD BARS
* RS13, S13, RPS13, PS13, S14, S15 - $149 (free delivery or pick-up)
* HNR32, BNR32, HCNR33 - $149 (free delivery or pick-up)
Does the Oil Catch Can come with instructions?
Also, the brake cylinder stopper... is the movement you're talking about causing my car to swerve slightly when I come to a hard stop? Will this product fix it up? Is it a direct bolt on to the R34 GTT?
yes it comes with instruction in japs though :D
The BCS basically keep the brake master cylinders from moving. Using Cusco’s Brake Cylinder Stopper, the unwanted flex of the brake master cylinder is prevented when the brakes are applied. Due to the high forces exerted against the bulkhead under braking, the Cusco Master Cylinder Stopper bolts upto the end of the master cylinder and vastly reduces bulkhead flex which in turn leads to a better brake feel.
yes it is direct bolt to R34. :P Pm me for more details mate..
CURRENT STOCK
* 180sx, RS13, RPS13, PS13 S14 - $119(free delivery or pick-up)
- TENSION ROD BARS
* 180sx, RS13, S13, RPS13, PS13, S14, S15 - $149 (free delivery or pick-up)
one cusco oil catch can sold today!
Popular question:
i often get asked whats the different between kit specific oil can and universal one
i sell the universal one only. and honestly there is no different. in fact the universal kit is better in my opinion as you are not retricted in the area that you want to mount it on.
whereelse the specific one, you need to mount only in that particular area.
the universal are good as if u decided to sell it away, you can sell it to anycar instead of the specific to the type that you have. eg an s15 specific oil catch can only fit to s15 car and nothing else.
the universal are easy to fit on as cusco mounting are designed in such a way that they are very eesy to put it on as you can see from the pics below.
hope that helps :D
1 cusco oil catch can
1 tension rod bar 180sx
1 cylinder brake stopper
SOLD TODAY
CURRENT STOCK
________________
* RS13, RPS13, PS13 S14 - $119(free delivery or pick-up) x 1 lLEFT
* S14, S15 - $119 (free delivery or pick-up) X 1 LEFT
* BNR32, HCR32, HNR32 - $149 (free delivery or pick-up) (SOLD OUT)
* BCNR33, BNR34 - $119 (free delivery or pick-up) X 3 LEFT
* ECR33, R34 - $149 (free delivery or pick-up) X 2 LEFT
- Upper Front Strut bar - Type OS (suit S14, S15) - $249 (free delivery or pick-up) (SOLD OUT)
- TENSION ROD BARS
* 180SX RS13, S13, RPS13, PS13, S14, S15 - $149 (free delivery or pick-up) (SOLD OUT)
* HNR32, BNR32, HCNR33 - $149 (free delivery or pick-up) X 2 LEFT
CUSCO OIL CATCH TANK WITH THE BRACKETS THAT ARE EASY TO INSTALL IN ANY CAR!
JUST LOOK AT THEIR BRACKETS AND YOU WHAT I MEAN! VARIOUS ANGLE, VARIOUS POSITION. NO PROBLEM!
s13 cylinder stopper SOLD OUT
CURRENT STOCK
________________
- OIL CATCH TANK 15mm HOSE (SUIT ALL NISSAN) BRACKETS INCLUDED. $169.95 (free delivery or pick-up)
* RS13, RPS13, PS13 S14 - $119(free delivery or pick-up) (SOLD OUT)
- TENSION ROD BARS
CURRENT STOCK
________________
- BRAKE CYLINDER STOPPER (A MUST ITEM FOR YOUR CAR!)
- TENSION ROD BARS
* HNR32, BNR32, HCNR33 - $149 (free delivery or pick-up) X 1 LEFT
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
