  • Replies 63
do you deliver to melbourne as well. im interested in oil catch can
yes. free delivery aussie wide for any product purchased. not only that. i throw in free registered post to ensure the parcel arrived safely! :)
S14/S15 UPPER FRONT STRUT BAR - SOLD OUT!
CURRENT STOCK
- OIL CATCH TANK 15mm hose, (suit all nissans) $169.95 (free delivery or pick-up)
- BRAKE CYLINDER STOPPER
* RS13, RPS13, PS13 S14 - $119(free delivery or pick-up)
* S14, S15 - $119 (free delivery or pick-up)
* BNR32, HCR32, HNR32 - $149 (SOLD OUT)
* BCNR33, BNR34 - $119 (free delivery or pick-up)
* ECR33, R34 - $149 (free delivery or pick-up)
- Upper Front Strut bar - Type OS (suit S14, S15) - $249 (SOLD OUT)
- Upper Rear Strut bar - Type OS (suit S14, S15) - $249 (free delivery or pick-up)
- Upper Front Strut bar - Type OS (suit R32. HNR32, BNR32) - $249 (free delivery or pick-up)
- Upper Rear Strut Bar - Type OS (suit R32. HNR32, BNR32, A31, C33, CA31) - $249 (free delivery or pick-up)
- Upper Front Strut bar - Type OS (suit BCNR33, BNR34) - $249 (free delivery or pick-up)
- TENSION ROD BARS
* RS13, S13, RPS13, PS13, S14, S15 - $149 (free delivery or pick-up)
* HNR32, BNR32, HCNR33 - $149 (free delivery or pick-up)
Does the Oil Catch Can come with instructions?
Also, the brake cylinder stopper... is the movement you're talking about causing my car to swerve slightly when I come to a hard stop? Will this product fix it up? Is it a direct bolt on to the R34 GTT?
yes it comes with instruction in japs though :D
The BCS basically keep the brake master cylinders from moving. Using Cusco’s Brake Cylinder Stopper, the unwanted flex of the brake master cylinder is prevented when the brakes are applied. Due to the high forces exerted against the bulkhead under braking, the Cusco Master Cylinder Stopper bolts upto the end of the master cylinder and vastly reduces bulkhead flex which in turn leads to a better brake feel.
yes it is direct bolt to R34. :P Pm me for more details mate..
CURRENT STOCK
* 180sx, RS13, RPS13, PS13 S14 - $119(free delivery or pick-up)
- TENSION ROD BARS
* 180sx, RS13, S13, RPS13, PS13, S14, S15 - $149 (free delivery or pick-up)
one cusco oil catch can sold today!
Popular question:
i often get asked whats the different between kit specific oil can and universal one
i sell the universal one only. and honestly there is no different. in fact the universal kit is better in my opinion as you are not retricted in the area that you want to mount it on.
whereelse the specific one, you need to mount only in that particular area.
the universal are good as if u decided to sell it away, you can sell it to anycar instead of the specific to the type that you have. eg an s15 specific oil catch can only fit to s15 car and nothing else.
the universal are easy to fit on as cusco mounting are designed in such a way that they are very eesy to put it on as you can see from the pics below.
hope that helps :D
1 cusco oil catch can
1 tension rod bar 180sx
1 cylinder brake stopper
SOLD TODAY
CURRENT STOCK
________________
* RS13, RPS13, PS13 S14 - $119(free delivery or pick-up) x 1 lLEFT
* S14, S15 - $119 (free delivery or pick-up) X 1 LEFT
* BNR32, HCR32, HNR32 - $149 (free delivery or pick-up) (SOLD OUT)
* BCNR33, BNR34 - $119 (free delivery or pick-up) X 3 LEFT
* ECR33, R34 - $149 (free delivery or pick-up) X 2 LEFT
- Upper Front Strut bar - Type OS (suit S14, S15) - $249 (free delivery or pick-up) (SOLD OUT)
- TENSION ROD BARS
* 180SX RS13, S13, RPS13, PS13, S14, S15 - $149 (free delivery or pick-up) (SOLD OUT)
* HNR32, BNR32, HCNR33 - $149 (free delivery or pick-up) X 2 LEFT
CUSCO OIL CATCH TANK WITH THE BRACKETS THAT ARE EASY TO INSTALL IN ANY CAR!
JUST LOOK AT THEIR BRACKETS AND YOU WHAT I MEAN! VARIOUS ANGLE, VARIOUS POSITION. NO PROBLEM!
s13 cylinder stopper SOLD OUT
CURRENT STOCK
________________
- OIL CATCH TANK 15mm HOSE (SUIT ALL NISSAN) BRACKETS INCLUDED. $169.95 (free delivery or pick-up)
* RS13, RPS13, PS13 S14 - $119(free delivery or pick-up) (SOLD OUT)
- TENSION ROD BARS
CURRENT STOCK
________________
- BRAKE CYLINDER STOPPER (A MUST ITEM FOR YOUR CAR!)
- TENSION ROD BARS
* HNR32, BNR32, HCNR33 - $149 (free delivery or pick-up) X 1 LEFT
    • Update Got turbo back from hypergear, installed everything etc. Bled coolant, wasn't smoking so I thought beauty she's sorted now. Went on a drive, car up to temp, let it idle for about 15 seconds, gave it some gas...nice puff of smoke again. Fml No doubt my turbo was pretty worn anyway but nonetheless frustrating that the problem persists.
    • Lol, yeh sure. But I'm not changing the head on this engine. Turbo is the current mod im looking at; as the VCT-2.6L  engine im building is getting the turbo setup i posted so the old built RB25DE needs a snail
    • New setup just needs a VCT enabled head and it will come on so much earlier. At least 500rpm of added response, if not more.
    • Wow, there's a user name I haven't seen for a while! Good to see you back @Sydneykid
    • Something to note, on an aftermarket BOV, it's quite possible to end up with the worst of both worlds, where on light throttle, there isn't enough force to open the BOV so you get small reversion and driveability issues, and with the venting to atmosphere, it dumps a lot of fuel on shifts. Realistically, dumping to atmosphere under power isn't a major driveability issues, compared to the issues of stalling from reversion. If you're getting up the throttle, then putting the clutch in, say on a shift up, but then don't release the clutch, yes, the engine can and will stall, but, just drive around it, and that's easy, let the clutch out in the next gear and the car rolling will keep it all running / going.who wants a hard hit of throttle and then to just let the motor idle anyway?   Main issue for driveability is blipping throttle and it wanting to stall, like when parking or trying to move in slow traffic.
